KCNC titanium brake and derailleur cables - bad experience!
lannes
by lannes
Foxtrot wrote:What is the weight of the Titanium cables ?
http://fairwheelbikes.com/kcnc-titanium ... -5506.html
jan erik
by jan erik
I thought that the stretch is not in the cable but in the cablehousing (or rather crimping)
shlammed
by shlammed
I know this is WW and all, but Im not sure how anyone can justify 100x the cost to save 0.15lbs...on a wear item.
CharlesM
by CharlesM
jan erik wrote:I thought that the stretch is not in the cable but in the cablehousing (or rather crimping)
You're confusing "stretch" (cable) with "compression" (housing). The reason you see the metal link housing is because it will not compress... The links will separate (stretch) very easily, but that's the opposite of the force they have on them.
Both things (stretch and compression) happen to some degree with a new system set up. You have to run the brakes a bit to "seat" the housing and ferules etc... Then adjust for the work load.
There isn't much stretch in any good cables... (at least not during simple actuation in the context of this thread)
This thread isn't about cable stretch (or likely about the cables at all)... It's a system / installer error.
