It is currently Thu Jan 18, 2018 3:11 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Feb 20, 2014 12:33 pm
So I pulled my carbons out the other day to look over them before my race on Saturday.
Obviously they were flat; however upon feeling the tyres, there is a hard patch in one -
about 6mm in length. I assume this is where the sealant has settled where I've been a bit
lazy with maintaining air pressure and turning the wheels? is there any way to fix this?
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Thu Feb 20, 2014 12:48 pm
If its a hard lump of sealant, more sealant *might* dissolve it. If its where the inside of the tube has stuck together, you are screwed.
Pump them up and give them a whizz, you might not even notice the lump when they are at 100+psi.
PostPosted: Thu Feb 20, 2014 12:55 pm
They pump up fine so I don't think it's the inside of the tube stuck together. Will give them a quick ride once the bike is clean and set up provided it's not raining....
PostPosted: Thu Feb 20, 2014 2:41 pm
That is one of the reasons I don't like sealant for tubulars. Really nothing you can do about it now, but I doubt it will make that much difference to your race. The other alternative would be to replace the tube, but that seems like overkill.
PostPosted: Thu Feb 20, 2014 3:06 pm
Thinking about it, the lump is only a bit of congealed latex and "gunk", maybe trying to crush it against the rim bed or between fingers might allow it to break down a bit more easily.
And make sure its not a lump thats dried up and hardened round a thorn/piece of glass first!
PostPosted: Thu Feb 20, 2014 4:56 pm
I would imagine riding it will disintegrate the latex if it has hardened. You could also figure out what the solvent is in the liquid latex and put some more of that in to break it up?
PostPosted: Fri Feb 21, 2014 12:49 am
The "solvent" in most sealants is glycol based-rv antifreeze is safe and works well-long thread on the mtbr board by some chemists about homebrew solvents. Not sure if you can dissolve a latex "booger" but worth a shot.
There are no new unread posts for this topic. Sram S500 aero shifter very hard to shift
LouisN
Fri Feb 10, 2017 11:19 pm
hack View the latest post
There are no new unread posts for this topic. Closing Rotor Inpower battery door insanely hard. Any tips?
Shrike
12
1187
Sun Jan 22, 2017 8:46 pm
wingguy View the latest post
There are no new unread posts for this topic. Tyre pressure opinions please.
JScycle
21
1910
Sat May 20, 2017 10:42 am
JScycle View the latest post
There are no new unread posts for this topic. Caad12 tyre clearance
Devotional1993
Sat Mar 18, 2017 4:11 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Bikeradar Tyre Test
Ozrider
29
3826
Sun Mar 05, 2017 1:51 pm
kgt View the latest post
Users browsing this forum: eric01, grumpier, Rioken, tonytourist, Voye, Yahoo [Bot] and 33 guests
