It is currently Tue Jan 17, 2017 1:55 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Thu Feb 20, 2014 3:50 am
Between these two great bikes. I intend to use this as my all-rounder and even take it on my weekend rides.
Any inputs?
PostPosted: Thu Feb 20, 2014 4:49 am
Given that you know both are great bikes maybe you can based your decision on your budget or the looks? Both are top end offerings so you can't go wrong either way
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
PostPosted: Thu Feb 20, 2014 5:02 am
But there must be differences between the two.
One might be more comfortable than the other, climb better, etc.
PostPosted: Thu Feb 20, 2014 10:19 am
Climbs as well as your legs will let it. I know you can't ride the Canyon, but find a BMC dealer and test ride the SLR. Neither bike will hold you back from what you want to do with it.
Which one excites you most when you look at it? That's the one you'll ride more.
PostPosted: Thu Feb 20, 2014 11:32 am
Copying this from another thread:
Lateral Stiffness (Higher the better)
BMC TeamMachine SLR01 101 Nm/deg
Canyon Ultimate CF SLX 9.0 SL 101 Nm/deg
BMC TimeMachine TMR01 95 Nm/deg
Canyon Aeroad CF 9.0 SL 85 Nm/deg
vertical compliance (lower the better)
Canyon Ultimate CF SLX 9.0 SL 92 N/mm
BMC TeamMachine SLR01 132 N/mm
Canyon Aeroad CF 9.0 SL 140 N/mm
BMC TimeMachine TMR01 322 N/mm
So between the two they are equally laterally stiff but the SLX is vertically more compliant. I own a SLX and can confirm that it rides over bumps like no other bike Ive ever owned
Strava
PostPosted: Thu Feb 20, 2014 12:35 pm
Both dream bikes, and would be my top choices. Test ride both, that's the only way.
The BMC looks a lit better in my eyes, but why buy that over the Canyon if it doesn't
fit your body/riding style as well?
Campagnolo; because I ride a bicycle, not a fishing rod.
M∆SON Definition / Camapgnolo endurance & bikepacking build - ~8.4kg
PostPosted: Thu Feb 20, 2014 3:45 pm
The Canyon is much cheaper, better and better looking.....so it's easy ;-)! If you want to spent more money and/or don't like the Canyon looks it's easy too. Real bestriding is mostly only possible on Canyon's test days. I don't know if BMC has that. Most dealer won't let you really test ride (a little round on the bike says almost nothing....)
Canyon CF SLX DA Di2 2014
Canyon Aeroad CF SLX DA Di2 2016
Canyon Speedmax CF Ultegra Di2 2015
PostPosted: Thu Feb 20, 2014 4:54 pm
I'm about to pull the trigger on a SLX frameset...
PostPosted: Thu Feb 20, 2014 7:10 pm
You mean order one with a mouse click?
PostPosted: Thu Feb 20, 2014 11:33 pm
well they are quite different frames...the bmc is known to be much more compliant compared to the canyon..the rear particularly.
like the test results above, i read a few others that support this..
i say let geometry decide, then looks (which they are very different as well)
Dogma 6710g
PostPosted: Fri Feb 21, 2014 12:55 am
Actually, the results above suggest the Canyon is more compliant.
My Bikes
My Photoblog
PostPosted: Fri Feb 21, 2014 1:50 am
I say, get the Canyon and save the money to get some badass parts to bling up your bike...
PostPosted: Fri Feb 21, 2014 6:45 pm
Get the canyon, I rode both back to back within 3 days in between. My two buddies have them and let me rode each. I say bmc feels lighter (2014 slr01) but the canyon just feels more planted around bends and easier to pedal effortlessly out of corners when I try to catch up to my group. I'm not the fastest or stronger one usually, but canyon slx does help a lot for that day.
PostPosted: Wed Feb 26, 2014 11:32 pm
I have both SLR001 (2012/53) and CF evo (not slx, 2011/54) both have sram red. 35000km on Canyon and 22000 km on BMC.
The only difference between two bikes is Canyon is more comfortable on bad roads and BMC is slightly more agile on descents. But they are old frames now, maybe the new ones more equal.
PostPosted: Thu Feb 27, 2014 8:25 am
i would get the Canyon regardless, wouldn't even consider the BMC personally ...
There are no new unread posts for this topic. Canyon Ultimate CF SLX 2017 Frameset?
stevec1975
Mon Sep 19, 2016 11:44 am
sawyer View the latest post
There are no new unread posts for this topic. Canyon Ultimate CF SL lineguide and dropout
dino0204
Tue Jun 07, 2016 6:11 pm
dino0204 View the latest post
There are no new unread posts for this topic. Colnago C60 vs Cannondale SS Hi Mod vs Canyon Ultimate
AGroot
21
2786
Tue Sep 27, 2016 1:22 pm
trimenc View the latest post
There are no new unread posts for this topic. Giant Overdrive 2 Headset on Canyon Ultimate CF SLX
emcardle
Fri Jan 29, 2016 2:39 am
Birdman View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon Ultimate Disc - First real picture.
Nejmann
22
4302
Fri Jun 10, 2016 9:28 pm
jeffy View the latest post
Users browsing this forum: Baidu [Spider], dwiller, Google [Bot], maverick_1, MSNbot Media, normcorriveau, TheDarkInstall and 42 guests
