It is currently Fri Oct 20, 2017 8:54 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Wed Feb 19, 2014 3:14 am
So bought dura 9000 but my Frame is pf30 thus a bb30 crank would be better.
So what is the better option for stiffness etc and is there a noticablw difference if I use an adaptor and 9000 crank vs bb30 crank? I am 75kg and do sprint pretty hard.
A red22 crank would be the obvious choice if I stayed all bb30. Ignoring the whole I can't have sram and dura mixed together. Which way would you go from scratch? And why?
PostPosted: Wed Feb 19, 2014 3:20 am
get yourself a Praxis BB30-HTII conversion BB. I dont use a praxis BB, but I have heard nothing but praise for these things. Much better than the other types of adapters.
http://praxiscycles.com/product/shimano-conversion-bb/
The New: BH http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=117760
PostPosted: Wed Feb 19, 2014 3:24 am
And you would do this (from scratch) instead of getting a bb30 specific crank?
Eg 9000 crank with adaptor > bb30 crank such as red 22?
PostPosted: Wed Feb 19, 2014 4:12 am
i, as with many people on this forum, wouldnt mix sram/shimano (even though you said it wasnt an issue for you) plus the new DA9000 crank is dam nice.
stiffness would probably be the same. Stiffer DA crank/Rings with potential losses in the adapter vs proper BB30 crank but with not as stiff sram rings.
PostPosted: Wed Feb 19, 2014 5:05 am
Thanks. Hmm I'm surprised the red cranks lag in stiffness much behind 9000.
What do these adaptors weigh? I looked at the link but couldn't see any weights
What about something like rotor cranks in bb30?
PostPosted: Wed Feb 19, 2014 5:54 am
why don't you get really crazy and use the Campag Over-torque BB30/BB386 crank?
PostPosted: Wed Feb 19, 2014 7:04 am
Image :welcome:
i'm using this on my ar1
Gil
Oregon
2014 Felt AR1 11 speep di2
2013 Felt F65x trp hyrd
PostPosted: Wed Feb 19, 2014 7:24 am
Stay with the 9000 crank. All you need is decent BB30 bearings in the frame and the wheels manufacturing adapters.
I run these on all my BB30 frames with my beloved fishing tackle. Cheap, Creak free and very easy to install.
http://wheelsmfg.com/bb-pf30-universal- ... ranks.html
PostPosted: Wed Feb 19, 2014 8:27 pm
This is a lot cheaper than the praxis above. Does it produce as good a result?
Experiences? Feedback?
PostPosted: Thu Feb 20, 2014 6:34 am
Hi all,
Thanks for the messages/questions on our Conversion BB. Some on this thread emailed us asking about the spec...
Our BB is designed right to Shimano spec which is why we have the bearings outboard. This puts all the pedaling loads exactly where Shimano designed the Hollowtech II spindles to take forces. It's not an adaptor , but rather a full proper bottom bracket for Shimano cranks on BB30, PF30, or Specialized OSBB road frames.
If anymore questions just give us a call at our Santa Cruz office or email info@praxis-works.com and we'll be glad to help.
Thanks for the interest!
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz, CA
www.praxis-works.com
PostPosted: Thu Feb 20, 2014 8:39 am
Hi as per my post. I've had excellent results with the wheels manufacturing adaptor. It doesnt crush into the frame like other makes. I had a k-zero screw in BB like the praxis and it cracked the paint on my BB. The wheels will not do this.
Just leave your bearings and circlips in and add adaptor.
PostPosted: Thu Feb 20, 2014 4:58 pm
I went with a bit of a pricier option with a CK BB and their conversion kit. Never had a creak and didn't have to downgrade shifting by going non shimano ;)
PostPosted: Thu Feb 20, 2014 5:43 pm
Keep the 9000 crankset.
I've had great luck with the wheels mfg or problem solvers adapters.
PostPosted: Thu Feb 20, 2014 9:25 pm
AptosBigRing wrote:
Hi all,
Adam@Praxis
Good info and thanks.
PostPosted: Mon Feb 24, 2014 11:00 pm
I've gone for the Rotor BB30 conversion kit. Like the Praxis, it's a full bb, not an insert for the existing PF30. I'll report back when the bike is built. Going from Rotor 3DF w/ Praxis rings to Ultegra 6800 (so same design as DA9000, but heavier/lower grade); be interesting to see if I can feel any difference.
There are no new unread posts for this topic. Attachment(s) Sram Red BB30 cranks & BB30A
meanmachine
7
2002
Mon Apr 03, 2017 5:08 pm
Valbrona View the latest post
There are no new unread posts for this topic. Caad12 disc with shimano crankset adaptor
martinfrias
Sat Oct 07, 2017 10:14 am
snowdevlin View the latest post
There are no new unread posts for this topic. Enve Garmin Mount - GoPro Adaptor Plate
Demthios
13
1755
Thu May 11, 2017 6:41 am
Erwin View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. 9000 left arm on 9100 crankset??
Delorre
Tue Oct 17, 2017 5:12 am
MomentumR5 View the latest post
Users browsing this forum: agfu, Bing [Bot], CP, crn, Delorre, Hexsense, JoO, Monkeyfudger, MRM and 51 guests
