It is currently Thu Jan 18, 2018 1:08 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Tue Feb 18, 2014 3:47 pm
I'm sure this has been asked before, but I can't find it. Has anyone tried to use a Cannondale hollowgram with the Rotor BB (the one that allows use of their BB30 crank on a BSA bike)? I thought I read somewhere the axel length is off, or something.
__________
Seven 622 SLX
Colnago C50 Extreme Power
Zanconato CX
PostPosted: Tue Feb 18, 2014 5:27 pm
You will have to do some research on spindle lengths available with the Cannondale, but I strongly suspect the answer is "no".
Currently there is what is effectively a "long BB30" standard evolving, otherwise known as BB386EVO. It uses a 30mm spindle but with the bearing spacing of a 386BB. (Which is derived from a regular old fashioned BSA BB with outboard cups). Right now FSA, Rotor and Campagnolo make these cranksets, possibly others too. It's a flexible solution for a wide variety of BB shell types, including BSA.
A "regular" or standard BB30 system puts the bearings closer together and uses a shorter spindle, which is probably what you have, although you need to be more specific about what crankset you have.
There's sometimes a buggy.
One.
PostPosted: Tue Feb 18, 2014 5:41 pm
Yes it can be done. You need a longer spindle and modify it a little bit.
If I remember correctly you need a 122 mm spindle.
As a result your chainrings will be 9mm more outward and the q-factor will be 18mm wider.
If you don't care about this it will be perfectly fine.
PostPosted: Tue Feb 18, 2014 6:45 pm
This illustrates another problem - primarily chainline and to a lesser extent the Q factor.
These problems would not be there in a "BB386EVO" type crank which would provide the correct chainline. I'm not sure you could get a FD that would work with a crank 9mm further away, plus the undesirable chain angles that would occur.
One.
PostPosted: Tue Feb 18, 2014 7:56 pm
The bad chain line and Q factor make the Cannondale conversion a non starter.
Sram Quark BB30 cranks are "long BB30". So are Lightning.
There are no new unread posts for this topic. 1x conversion
illlili
Tue Sep 26, 2017 12:05 am
bm0p700f View the latest post
There are no new unread posts for this topic. Canyon SLX Disc mechanical frame Di2 conversion
hannawald
22
2709
Tue Oct 10, 2017 6:03 am
marioc View the latest post
There are no new unread posts for this topic. Cervelo S3 2014 - Internal battery conversion
Xcessiv
Wed Feb 15, 2017 12:01 am
hambini View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1289
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2938
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], izza, olir, Super Guanche, Yahoo [Bot] and 32 guests
