It is currently Sun Jan 21, 2018 7:31 pm
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: 7700 STI won't downshift
PostPosted: Tue Feb 18, 2014 3:10 pm
Hi! what's the remedy for right Dura Ace 7700 STI that requires to be held still and only then will downshift...
I heard of air blasting and WD40 but it doesn't work
thanks ;)
PostPosted: Tue Feb 18, 2014 4:27 pm
You sure this is not a cable friction issue? Have you checked that the cable routing is smooth, tension is proper and that the cables and housing are playing nice with each other?
PostPosted: Tue Feb 18, 2014 7:52 pm
Make sure the cable has not frayed. That normally happens inside the shifter.
The grease that Shimano uses tends to harden and gum up the shifter. That makes the mechanism not catch. On my 7800 levers with this problem the symptom is that the upshift lever will move but not shift. It can take a couple stabs at the lever to get it to shift. It's worse in the cold.
The levers also have noticable stickiness when you move them. On advice of a shop owner friend who has done this many times I used "CRC Powerlube". Squirt it into the mechanism and let it drip out. Do it a couple times. It sees to have cleared it up. WD40 isn't a lube. Although it would dissolve the grease it would not lubricate the mechanism.
PostPosted: Tue Feb 18, 2014 9:18 pm
It was a known problem with that model. You need a replacement part, can't remember which one though...
PostPosted: Tue Feb 18, 2014 9:26 pm
I don't think there are any replacment parts for the shifters.
There are no new unread posts for this topic. DA7710 175mm or DA 7700 175mm which is lighter?
nelsontod
Sun Aug 13, 2017 4:53 pm
nelsontod View the latest post
Users browsing this forum: Attermann, Google [Bot], themidge and 38 guests
