Help to verify freehub body replacement
sdexter
by sdexter
hi all,
I'm very new here and at the moment i had a project that has to be postponed due to GS doesnt fit freehub body.
So my WS is Fulcrum racing 1 (2012 version) and i used ultegra 6800 GS.
Im thinking to replace the freehub body better then get a new set of WS such as mavic ksyrium, etc.
I've been searching on *bay and found couple, but im not 100% sure, there for i need help to verify is the freehub body fit my WS
here's the link:
http://www.ebay.ca/itm/Fulcrum-Campagno ... 51b8d58f72
Geoff
by Geoff
Welcome.
I think that you are saying you have a Fulcrum wheelset with a Campagnolo freehub. You are running a Shimano Groupset and need to convert the freehub. If that is accurate, the link that you had posted should work for you.
jekyll man
by jekyll man
That's not quite how I read it Geoff-
Its the ebay link that's misleading.
Its a 10spd shimano wheel, but the groupset is 11 speed. Needs a redesigned freehub.
It might fit, but i'm not sure if a shorter NDS spacer is needed too.
The other option is to get a campag freehub body, and run an 11 campag cassette...
Official cafe stop tester
sdexter
by sdexter
sorry if my request for help is not clear.
So im building a new bike with ultegra 6800, and i got an older version of Fulcrum racing 1.
The fulcrum racing 1 freehub body is for 10speed.
I planned to replace the freehub body with 11 speed so i can use my ultegra 6800 without buying a whole new wheelset.
After searching on ebay, i found that link on my post above.
But i couldnt get clear description regarding the fitment, there for i need help to verify
ultimobici
by ultimobici
Why not try your lbs?
Causidicus
by Causidicus
sdexter
by sdexter
Causidicus wrote:
sdexter wrote:I planned to replace the freehub body with 11 speed so i can use my ultegra 6800 without buying a whole new wheelset.
Look in the Fulcrum or Campagnolo parts catalogues.
You need Fulcrum RS-113 or Campagnolo FH-BUU015X1. Same part.
thnx Causidicus.
i have no experience in replacing freehub before,
does rs-133 or fh-buu015x1 need longer axle?
I hope this is just as simple as just open the fastener bolt and install the new freehub body
Causidicus
by Causidicus
sdexter
by sdexter
sweet, thnx Causidicus
nealrab
by nealrab
I was in the same predicament recently with an older Fulcrum R1 set that was never used, but I decided to keep the old freehub for Shimano 8/9/10 and just went with Ultegra 6700. Would be interested to hear how the freehub switchout went when you're done sdex...
goodboyr
by goodboyr
I switched over a fulcrum zero recently. Causidicus time estimate is just about right!
