It is currently Mon Oct 16, 2017 11:38 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 17, 2014 7:18 pm
You are crazy :) but I think you will be happier with the Roubaix fit-wise.
And as mentioned before, I wouldn't go with a Dorico seatpost; I found the clamping mechanism to be sub-par. Maybe a Fizik Cyrano (if you still need to switch out the seatpost on the Roubaix)?
My Bikes
My Photoblog
PostPosted: Mon Feb 17, 2014 8:35 pm
The Roubaix comes with the one in the picture so it has setback. Its a heavy post so I might change it down the line as it will give me some time to look around. Hopefully I can get the bike to work with the 6 degree 80mm 3T ARX stem so I can keep using my Tillquist Garmin mount.
PostPosted: Mon Feb 17, 2014 8:51 pm
Man, I would not sell or buy a bike until the fit is dialed in. You could easily flip the stem downwards, which would move your hands down an inch and still be fairly upright.
Gramz
Failed Custom Bike
PostPosted: Mon Feb 17, 2014 10:39 pm
The goal was not to get the bar lower but to get it higher???
PostPosted: Mon Feb 17, 2014 11:06 pm
I think he was saying that the headtube on the Roubaix might be tall enough to allow you to run the stem flipped down and still have the handlebar high enough to suit your needs.
My Bikes
My Photoblog
PostPosted: Mon Feb 17, 2014 11:37 pm
Got that makes more sense. I hope to be able to run a 3T 80mm 6 degree stem. The stem that is on there in the picture is from my new mountain bike. Have to measure it all out. There is also a good amount of steer to allow further adjustment too.
PostPosted: Tue Feb 18, 2014 12:06 am
I get that, but you're acting as if this brand new position is final. You had doubts the bars should even be where they are, but then bought a bike based on that height- it doesn't make sense. Why not get the fit adapted/dialed then assuming that this is it? You didn't like the flipped up stem and spacers on the old bike, which I get, so you get a new one just so you can have less spacers when you don't even know if that amount is final.
Gramz
Failed Custom Bike
PostPosted: Tue Feb 18, 2014 4:34 pm
Not sure if I explained it the right way but as fa63 knows with the body type I have it makes much more sense with the higher HT. It may sound like its something I rushed into but there is a lot more that goes into than what I have written. I have no doubt the my bar needs to be higher as I have raised the seat up much higher than where I have had since I got the bike. I had gotten used to low seat riding DH and freeriding mtb.
There are no new unread posts for this topic. bike fitting and suggestions help
bigpab
Sun Jan 22, 2017 11:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Selle SMP saddles - advice on fitting and model selection?
rynogee
11
1578
Mon Dec 26, 2016 5:32 pm
ryanw View the latest post
There are no new unread posts for this topic. Rim brake advice and feedback needed
woogie11
11
701
Sat Aug 26, 2017 11:40 am
Marin View the latest post
There are no new unread posts for this topic. WR Compositi Rims- thoughts & feedback
Wookski
Sun Mar 12, 2017 6:15 pm
Seedster View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], JeffK and 29 guests
