Women's Carbon Frames
Valbrona
by Valbrona
Would anyone be kind enough to add to my list? Must be carbon ... must be designated for women ... must be available as a frameset only. (Yes I know lots of small frames might just be as useful).
Fuji Supreme
Specialized Amira
Mario Jr.
by Mario Jr.
Ridley Liz
rmerka
by rmerka
All the WSD Treks.
bombertodd
by bombertodd
Pinarello Paris Easy Fit
Valbrona
by Valbrona
rmerka wrote:All the WSD Treks.
Thanks for your suggestion, but I think the Trek WSD 'concept' is actually a con. As far as I know they are based around regular frames, and the only thing that makes them 'WSD' is a short stem, narrow bars, short cranks, etc.
bombertodd
by bombertodd
Are you buying your special lady a new bike?
Valbrona
by Valbrona
bombertodd wrote:Are you buying your special lady a new bike?
I am sure as hell not. Females have driven a wedge between me and my bike in the past, and now nothing gets in the way of me and my bike. Women are just bad if you are a cyclist. Alll those hours shopping when I could have been out on my bike.
I am just a short reach kind of guy, and nowadays I also like a lot of stack.
spdntrxi
by spdntrxi
specialized ruby.. comp, pro,sworks little more laid back then then amira
cyclenutnz
by cyclenutnz
Valbrona wrote: but I think the Trek WSD 'concept' is actually a con. As far as I know they are based around regular frames, and the only thing that makes them 'WSD' is a short stem, narrow bars, short cranks, etc.
All 'womens' bikes are a con. What kind of stack and reach are you looking for? What are you riding now?
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
audiojan
by audiojan
There's in essence 3 types of "woman specific bikes", the ones that take a unisex model and slap some pink paint on it, the ones that take a unisex bike and change out the components (narrower handle bars, shorter crank length, women saddle, etc) and the very few that are truly designed with different geometry, different carbon layup etc.
The shorter you are and the lighter you are the more of a difference it will make. If you're taller, and more powerful, then a unisex frame may very well be a better choice.
With all that said, Parlee for example doesn't make a woman specific frame, but my wife has a Z5Sli XS/Tall and it beats out her woman specific frames (Orbea Orca Dama, Orbea Diva, Trek Madone WSD, Specialized Ruby, etc.) by quite a margin. She's quite short (5'2") and quite light (~110-115lbs), but packs some power. Don't discount a frame because it's not marketed as "woman specific".
LouisN
by LouisN
Ridley Frames.
Louis :)
Franklin
by Franklin
You all realize that a "woman's bike" is beyond ridiculous from a bodymetry standpoint? The differences between women and men are negligable in this regard. There is a very, very, very good reason all experienced women simply buy male models. They do not need a female model.
As a side note, that's even true for saddles. Women saddles are absolutely unsuited for racing. And if someone mentions Terry Saddles? Well, guess what, those Terry's work quite okay for a lot of males as well.
Now on your issue: all you need to know is your reach and check manufacturers. No need to spend extra for inferior bikes (women's bike invariably are equiped worse than a comparable male model).
Geoff
by Geoff
I have my girlfriend on the Cannodale Synapse. It is perfect for her.
spdntrxi
by spdntrxi
my wife is not tall… 5ft and about 100#… the WSD bike was good for her, I ended up getting her a Ruby Comp full ultegra… sure I've changed a few things here and there.. went from 75mm stem to 90mm, but most other fit things have remained the same. She's not a racer, so going all out comfort is the goal.
The bike is mostly black (matt black) with a touch of gold (stripe).. not girly at all.
