It is currently Tue Jan 23, 2018 11:25 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: Clear coat suggestions
PostPosted: Thu Feb 13, 2014 7:50 pm
I'd like to spray a layer of clear coat over my Enve seatpost to turn it from matte to gloss. Is there any real difference in clear coats? If so, what's best for this application?
Thanks,
Chris
PostPosted: Fri Feb 14, 2014 2:04 am
I would also be interested in this topic. How much prep sanding should be done?
Cheers,
GG
PostPosted: Fri Feb 21, 2014 3:49 am
What don't you like about the matte finish? If the clear coating process is not spot on, the post would probably look worse than when you first started. You could always invest in a Syntace P6 Hiflex post...glossy and fabulous!
PostPosted: Fri Feb 21, 2014 4:05 am
rough guide:
viewtopic.php?t=53264
viewtopic.php?f=10&t=87900&start=15
and use this for the clear coat..
http://www.halfords.com/webapp/wcs/stor ... yId_165505
welcome to the forum guys...check out the search function up top and use the relevant key words but the above links should do.
Dogma 6710g
PostPosted: Fri Feb 21, 2014 6:39 am
I would let a pro paint it for me, the clear coat is the hardest paint to paint :-)
PostPosted: Fri Feb 21, 2014 1:30 pm
Its not that hard. If you want the Enve logos removes, use some semi fine paper (320) Top it of with something at +600. Then clean the post with acetone. Don't touch the carbon, and then spray with some clearcoat. The 2 things that can go wrong is A) Clearcoat will crumble. Usually because of fingerprints or any other dirt. B) Too much spraying will make the coating drip. Making waves on the surface. Do the clearcoat over 2 or 3 times instead of one heavy spraying.
Edit: And some clearcoat comes with glimmer. Unless you really like it, you should avoid those.
PostPosted: Fri Feb 21, 2014 4:15 pm
The Enve matte finish doesn't match the finish on my Cervelo and it's kind of conspicuous. I've painted frames and parts before, so I have some experience and a pretty steady hand. I've never seen that Syntace post before; I'm not a big fan of two-bold designs, but that looks pretty darn slick. Thanks!
Chris
PostPosted: Fri Feb 21, 2014 4:30 pm
canbakay wrote:
rough guide:
Thanks for the links. I used the Search function initially and found it to yield much ado about nothing really relevant.
Chris
PostPosted: Fri Feb 21, 2014 4:34 pm
Thanks for this. If I don't want to remove the Enve logos, how best to clean the post prior to applying the clear coat. (I assume using acetone will remove the logos.)
Chris
There are no new unread posts for this topic. TRP r979 eq ?? Will they clear 27mm wide rims?
Allen254
Sun Mar 05, 2017 7:39 am
Nefarious86 View the latest post
There are no new unread posts for this topic. New Fork for the Look 585. Suggestions?
Catagory6
Thu Dec 07, 2017 3:41 pm
Svetty View the latest post
There are no new unread posts for this topic. First Power meter suggestions
[ Go to page: 13 4 5 6 7 ]
merser
91
8325
Wed Aug 02, 2017 5:38 pm
evan326 View the latest post
There are no new unread posts for this topic. Suggestions for finishing bar tape ?
wobbly
22
2012
Sat Jul 15, 2017 6:11 am
There are no new unread posts for this topic. Birthday build.... looking for suggestions
jever98
7
848
Mon Mar 06, 2017 10:35 am
jlok View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], uraz, Zakalwe and 35 guests
