It is currently Wed Jun 28, 2017 3:17 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sun Feb 09, 2014 6:57 pm
Does anybody know if 25 tyres will have enough clearance? I'm thinking of Vitoria corsas or continental gp3000.
Thanks
PostPosted: Sun Feb 09, 2014 7:27 pm
In my CX-1 or a friends CLX and Arte they don't have enough clearance. THey scratch the frame :( I bought a set of 25mm GP4000s just to keep them in a box.
PostPosted: Sun Feb 09, 2014 9:21 pm
I've fit 27mm Vittoria Pave tubulars on my 56cm Colnago Extreme Power with acceptable room. 25mm should be fine.
PostPosted: Mon Feb 10, 2014 4:14 am
My EPS on GP4000s 23c tyres have about 8~10mm clearance all round. 25c for a Continental tyre should be fine.
But as for Vittoria, may not be so as Conti tyres tend to run smaller than most of the other brands. My previous Pro3Race 23C and Ultremo were definitely bigger compared to my GP4000s in 23c.
PostPosted: Mon Feb 10, 2014 5:09 am
@octav that's a little odd, I'm running 25's on my cx-1 ..
PostPosted: Mon Feb 10, 2014 3:52 pm
My EP would clear the 27mm Vittoria tires, you will be fine. Those were even on Stan's Alpha rims, which are quite wide and make the tire even bigger.
PostPosted: Tue Feb 11, 2014 8:20 pm
FMB Paris Roubaix 25mm clears perfectly fine on my EPS.
PostPosted: Fri Feb 21, 2014 6:23 am
Lots of clearance on my EP for 25mm tires...like B-lab states you may even get decent space with 27mm's also.
PostPosted: Fri Feb 21, 2014 12:22 pm
Remember there's a difference in fitting Tubulars and clinchers as Clinchers have a larger circumference for the same sized tyre, so a 27mm width tubular may fit where a 25mm clincher may not.
 Post subject:
PostPosted: Fri Feb 21, 2014 12:24 pm
 Post subject:
PostPosted: Fri Feb 21, 2014 3:47 pm
It fits, but it scratches the frame when you pass through some water/ sand etc.
So a 23 Michelin would be the best I could get I think.
A 25 tubular fits for sure :)
There are no new unread posts for this topic. 2013 Northwave extreme tech SBS vs current extreme tech shoes
Delorre
Wed Apr 19, 2017 7:37 am
mrlobber View the latest post
There are no new unread posts for this topic. Colnago Super vs Colnago Master X-light
Kupepe
Sun Jan 08, 2017 6:57 pm
Kupepe View the latest post
Kupepe
Tue Jan 10, 2017 8:19 am
Zakalwe View the latest post
There are no new unread posts for this topic. Northwave Extreme RR shoes 2017
dolophonic
22
3674
Mon May 01, 2017 11:53 am
Rev View the latest post
There are no new unread posts for this topic. the weight of air in our tyres
Delorre
13
2014
Fri Jan 20, 2017 3:29 pm
964Cup View the latest post
Users browsing this forum: DRAwpt, grover, svendsvin and 26 guests
