It is currently Mon Jul 24, 2017 3:58 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Sun Feb 09, 2014 4:52 pm
ok, simple question.
When installing a 10spd shimano cassette on a shimano freehub, in what order do you put the washer and mini spacer that sit underneath the rest of the sprockets?
I cant remember if it matters or not and cant compare to other wheels as they all run mavic freehubs which do not have the same setup.
thanks and apologies for the question!
PostPosted: Sun Feb 09, 2014 4:57 pm
Depends on the Shimano hub. They made a DA hub that was 10sp only for a while. It uses no spacer. Those have an aluminium freehub body which has stepped splines that are taller for the larger cogs and shorter for the small cogs. But most are made from steel or Ti and use a 1mm spacer between the hub and cassette. Their splines are a constant height all the way across the body.
Normally there is only the 1mm spacer, no washer. Mavic freehubs are longer and need a Mavic spacer to get to 9/10sp width and then the Shimano 1mm spacer for 10sp cassettes.
Here you can find the instructions for installing shimano cassettes.
http://techdocs.shimano.com/techdocs/bl ... ID=keN_c7f
PostPosted: Sun Feb 09, 2014 5:11 pm
The hub came as standard on a dura ace c24 if that helps
PostPosted: Wed Feb 12, 2014 10:32 am
If it's a Shimano hub then you should only need the 1mm spacer that comes with the cassette. It should go on first before you put the largest cog on.
PostPosted: Wed Feb 12, 2014 7:33 pm
You do not user the spacer for the 7800 hub with the stepped 10sp splines.
There are no new unread posts for this topic. Attachment(s) SRAM or Shimano 11 speed cassette
DeLuz
33
1927
Wed May 03, 2017 12:59 pm
muntos View the latest post
There are no new unread posts for this topic. Zipp hub 177 and Shimano cassette issues
dorin
Wed Jan 25, 2017 3:48 pm
joejack951 View the latest post
There are no new unread posts for this topic. Shimano CS-9000 cassette vs. CS-9100?
[ Go to page: 1 2 3 4 ]
eaglejackson
50
8596
Sat Apr 15, 2017 5:31 am
James0133 View the latest post
There are no new unread posts for this topic. Need a good value climbing cassette: 11-30, or 11-32 (SRAM/Shimano)
Shrike
38
2717
Fri Jun 23, 2017 5:15 am
basurper View the latest post
There are no new unread posts for this topic. Shimano cassette body for Mavic R-SYS SLR 2015 wheel
Tillquist
Tue Jun 27, 2017 6:26 am
Tillquist View the latest post
Users browsing this forum: Baidu [Spider], iamraymond, MoPho, ntkt, Posix1b, sk1324, snowdevlin and 53 guests
