It is currently Thu Feb 23, 2017 3:12 pm
Post new topic  Reply to topic  [ 94 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Tue Feb 04, 2014 4:30 pm
The review is here: http://www.pezcyclingnews.com/page/latest-news/?id=118846
Really good stuff.
charles@pezcyclingnews.com
PostPosted: Tue Feb 04, 2014 4:48 pm
Resident master of GIF
wow! good review thanks for sharing!
Nate ★ Life , my tumblr joint
Instagramz
PostPosted: Tue Feb 04, 2014 6:04 pm
I love mine, especially when paired with TrainerRoad.
PostPosted: Tue Feb 04, 2014 7:07 pm
Charles is the best.
For an additional confirming opinion, check this:
http://www.dcrainmaker.com/2013/03/fitn ... eview.html
I just got one. Far and away the best I've ever seen, and that includes the SRM, Velotron, Computrainer, professional ergos, and others. Totally worth the money and the software and telemetry interfaces will only make it more valuable over time.
PostPosted: Tue Feb 04, 2014 7:58 pm
What's the feel like compared to the Lemond Revolution?
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Tue Feb 04, 2014 8:08 pm
Love mine as well... They have some growing pains.. But tech support is top notch . I'm on my second one.
PostPosted: Tue Feb 04, 2014 9:19 pm
Found the answer I was looking for in dcrainmaker's review. I've been on the Lemond and can concur with dcrainmaker's assessment that the Lemond's road feel is very realistic. According to dcrainmaker the Kickr's road feel is "sorta realistic". But damn, the Kickr sure has a lot of fancy features. So, for features... the Kickr. For feel, the Lemond. Downside to the Lemond is most definitely the noise however. No good if you're in an apartment or something.
Colnago C60 - PR99
PostPosted: Tue Feb 04, 2014 11:54 pm
I'd rate the Kickr road feel as better than the Lemond's. Hands down. Smoother and longer spin up and spin down, none of that "riding on awful tires" feeling, and very smooth and linear progression of resistance. I think what DCRainmaker noticed was that you can put extremely high resistance onto the Kickr, significantly more than the Lemond. If you turn up the effective resistance higher on the Kickr, then yes, you feel resistance, more than you feel on the Lemond which doesn't get that high. Try them both at, say, 200 watts, and they are as smooth with better windup and wind down on the Kickr.
PostPosted: Wed Feb 05, 2014 3:03 am
Interesting. I can't compare the two one way or another, since I've only been on the Lemond. But I do like how it feels, for sure. I like that the resistance is created as a result of your pedaling, and you can run through the gears, just like on the road. I'm not wanting for any more resistance than I can produce through pedaling. I think that's why DCRainmaker may think it feels more "real"... when you get on a bike and start riding, there's little if any resistance. As you pick up speed, it gets harder. Only downside to the Lemond I've found is the noise. DCRainmaker certainly said that you can add resistance to the Kickr, unlike the Lemond, however he also described the feel as "very real" on the Lemond vs "sorta real" on the Kickr. I don't know. But you've ridden both, right? So with conflicting answers, like anything in life with conflicting answers, guess I'll just have to try one myself if I get the chance. Thanks for your input. When you say there's "none of that awful tires" feeling, you must be referring to trainers other than the Lemond, right... since both the Lemond and the Kickr have the rear wheels removed when in the trainer.
Colnago C60 - PR99
PostPosted: Wed Feb 05, 2014 3:59 am
Calnago wrote:
Interesting. When you say there's "none of that awful tires" feeling, you must be referring to trainers other than the Lemond, right... since both the Lemond and the Kickr have the rear wheels removed when in the trainer.
Correct. But I would also say that if you try to do high wattage efforts on the Lemond, it acts like all fan units and starts to drag because it can't clear the air from the turbine area. With the Wahoo there's no need to clear air so you don't have physical limitations that alter the linearity of the power curve. Again, that makes me favor the Wahoo.
PostPosted: Wed Feb 05, 2014 4:15 am
Hmmm, I don't think the Lemond does act like all fan units simply because of the huge flywheel. ?? I'm not sure what you mean when you say it drags with high wattage efforts. Oh well, I'll give it a go just for kicks when I find one. Was just curious about it. Thx. Truth is, I hate stationary trainers of any kind, which is why my Lemond mostly collects dust. :).
Colnago C60 - PR99
PostPosted: Wed Feb 05, 2014 5:48 am
When paired with TR does the wahoo act similar to a computrainer. Is the load generated for you without the need to shift?
 Post subject:
PostPosted: Wed Feb 05, 2014 5:54 am
PostPosted: Wed Feb 05, 2014 5:56 am
Is this quiet enough to be used in an apartment? Will people below hear?
Current Stable:
The Snob Machine
The Ex's:
Litespeed Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | Litespeed Xicon: 5.76kg | Colnago C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg
PostPosted: Wed Feb 05, 2014 2:31 pm
nice thick rubberish type mat and I would think you would be ok
There are no new unread posts for this topic. Wahoo Kickr2 or Kickr Snap...
parajba
10
943
Fri Dec 23, 2016 4:23 pm
reknop View the latest post
There are no new unread posts for this topic. Wahoo ELEMNT first impressions
Krackor
29
6332
Mon Nov 21, 2016 11:16 am
ToffieBoi View the latest post
There are no new unread posts for this topic. Cyclemeter and iPhone, new Garmin, or Wahoo??
BigPoser
Fri Sep 16, 2016 11:15 pm
glepore View the latest post
There are no new unread posts for this topic. Turbo Trainer for a C60
TomColnago
Sat Jun 25, 2016 3:07 pm
showdown View the latest post
There are no new unread posts for this topic. Attachment(s) Trainer Voids Canyon Warranty
[ Go to page: 1 2 3 4 ]
asv
45
3564
Tue Feb 21, 2017 6:49 am
alastairb View the latest post
Users browsing this forum: amtbr, Baidu [Spider], benzebub, Bing [Bot], gmarsden, loudtiger, lovinmylab, Orlok, Pepsi, Yahoo [Bot] and 36 guests
