It is currently Thu Jan 18, 2018 1:24 am
Post new topic  Reply to topic  [ 64 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Mon Feb 03, 2014 1:49 pm
I need help to choose what I do about my road pedals. I'm currently using look keo 2 max road pedals and I realized my left pedal is a little locked, I opened and noted that the inside bearing not spinning well, I removed dust cap and I see some metal scraps inside bearing, I don't know if is possible replace this bearing but I'm thinking to buy a new pair of pedals. I'm a road bike for about 10 years but I used only 2 models of pedal, a campagnolo chorus pro fit (I think it a little narrow) and the look keo 2 max (better than campagnolo but not so much). I'm looking for a durable pedal more than a light one, and mainly a pedal that offer a good fit. I'm think about Time Xpresso (cleat is durable?), shimano dura ace (my bike is a colnago full campagnolo, so...), speedplay zero (those big cleats) and I accept suggestions. My shoes are sidi ergo 2, I have a little wider hip (narrow pedals tends to cause pain in outside part of my foot), I weight around 98kg and I ride sportively and participate occasionally races. Any help/opinion are welcome.
PostPosted: Mon Feb 03, 2014 3:41 pm
Shimano DA SPD-SL pedals are probably the most durable modern pedal. Between 7800 and 7900 pedals I have had to do one rebuild once in the last 10 years (and that was just disassembly, cleaning and regreasing- no parts needed to be replaced). I ride 550-700 hours a year.
The cleats last a long time and the pedal (and cleat) are wide making a large platform.
PostPosted: Mon Feb 03, 2014 4:17 pm
+1 to everything eric says about Dura Ace
I am using Speedplay, because I like a lot of free float.
Time xpressos are very light and have quite a bit of free float
It seems like all the modern pedals are really pretty good, with minor trade-offs and features for personal preferences.
PostPosted: Mon Feb 03, 2014 5:08 pm
marcio riva,
I had the same problem as you.
I'm also riding a Colnago with Campy and Ergo 2 shoes and I also have wider hips witch yelds the same problems (outside foot pain).
I'm using the Keo blades witch are good but not super perfect. I'm considering the DA pedals overlapping the fact its a style no-no for a Campy c59.
I'll follow this topic as I might get some new insights.
PostPosted: Mon Feb 03, 2014 6:41 pm
Keywin pedals might be a good option. They are quite light, when compared to other pedals at similar price. On the fit side, you can chose fixed or 6 deg float by installing a pin in the pedal (same cleats). You can also order them with longer or shorter spindles.
They are a bit rare, but you can now find both the CRM (older) and Carbon (newer) versions in US. I have received mine a few days ago, but did not have a chance to install / test them. I cannot comment on durability or reliability yet, but I heard only good thing about them.
There is a review of the CRM version here in WW.
PostPosted: Mon Feb 03, 2014 6:46 pm
If it's about fit, comfort and enjoyment of riding, screw the naysayers and get the DAs.
PostPosted: Mon Feb 03, 2014 7:03 pm
Yup, Dura-Ace all day long. I have a Colnago too, and when I built it up I was going to do an all "Euro" build, so I put Look Ti-Blades on (plus I also wanted to try them out). And also tried a different saddle than what I was used to. The pedals were the first to go, after only about 100 miles... back to Dura-Ace. The saddle was next.
Never a problem with Dura-Ace, and the cleats are nice and wide and you can actually walk ok with them, plus they last a good long time.
Long time ago, I had Campy Record Pro-fit, just cuz they were campy and everything else on my bike was too. Nowhere near as nice as Dura-Ace. Pedals, saddles, bars... go with what works, not what you think looks best on your bike or goes with whatever, although (big caveat) if you can satisfy the aesthetic part as well, then by all means go for it. Nothing is nicer than a well put together bike that fits, is functional, and looks the biz, in that order. I think the Dura-Ace pedals don't clash with whatever group or bike you are using. Ha... the other day while cleaning out a closet I even found an old pair ('91 o'92) of Time Magnesium Equipe (white) pedals that I used for a while as well. I really do need to have a big garage sale.
Colnago C60 - PR99; C59 Five Years Later; My Special Colnago EPQ
Trek Emonda SL Campagnolo SR; Trek Koppenberg - Where Emonda and Domane Meet
PostPosted: Tue Feb 04, 2014 9:37 pm
I'll second the Keywins. Awesome pedals!
PostPosted: Tue Feb 04, 2014 10:11 pm
Another vote for Shimano, does it really matter if the rest of your bike is Campag??
I did have Time RXS, but compared to Shimano they're really narrow and the cleats are pretty heavy with that big metal chuck there.
PostPosted: Tue Feb 04, 2014 11:38 pm
Plenty of keos on ebay at attractive prices.......
PostPosted: Wed Feb 05, 2014 12:15 am
I'm considering the pd-9000 da pedals too over my speedplays, I'm not a fan of the speedplay bearings.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
PostPosted: Wed Feb 05, 2014 1:07 pm
I want to thank you all for helping me.
I don't pretend to use keo again, the cleat wear in relative short time creating a groove where the pedal hold the cleat and increase the side play and the cleats showed wear in the outside making me think that I need a pedal with a wider plataform or longer axle, and the bearings are questionable. That said I am seriously thinking about buying the Dura Ace PD9000 with +4mm axle.
PostPosted: Wed Feb 05, 2014 3:06 pm
I'm using the Time Xpresso 12, have always like the combination of rotational and lateral float, also useful being able to adjust the Q factor.
Cleat wear is similiar to the Shimano, as it has pontoons to walk on.
The only issue is the pedal is so light it doesn't have the weight to hang vertically all the time, sometimes it takes a bit longer to get clipped in as a result.
PostPosted: Wed Feb 05, 2014 4:28 pm
Go shimano.
Reliable and good looking. Easily mantained.
I have had several types from base level to 105 and above and had no problems.
PostPosted: Wed Feb 05, 2014 4:59 pm
Administrator
Time Xpresso 12 times 2. Works well enough that the Xpresso 8's are now on my tt bike.
RESIDENT GRUMPY OLD MAN.
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
19
1627
Thu Nov 30, 2017 5:32 pm
Rick View the latest post
There are no new unread posts for this topic. Can I make this bike a lot ligher?
dim
Tue Dec 05, 2017 12:25 pm
alcatraz View the latest post
There are no new unread posts for this topic. How to make my Ridley Noah SL lighter??
fonzo89
12
1764
Thu Jul 06, 2017 10:55 am
hannawald View the latest post
There are no new unread posts for this topic. Anyone tried to make their own carbon orthotics/shoes
zappafile123
Sat Oct 28, 2017 6:23 pm
TheKaiser View the latest post
There are no new unread posts for this topic. can i make a 54cm frameset fit me for a trainer setup (normally on a 56)?
motorthings
10
859
Thu Nov 02, 2017 4:35 pm
motorthings View the latest post
Users browsing this forum: AZR3, beatle, MagicShite, nestornnk, topflightpro and 42 guests
