It is currently Wed Mar 29, 2017 10:07 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 Next
 Post subject:
PostPosted: Sun Feb 08, 2004 1:30 am
Nah, just making them on my spare time, and having them machined at a local shop.
 Post subject:
PostPosted: Sun Feb 08, 2004 2:24 am
So you called this your next project.What was your first one?
 Post subject:
 Post subject:
PostPosted: Sun Feb 08, 2004 2:31 am
Aluminum speedplay pedal inserts, reduces weight of X/1's to 128g.
 Post subject:
PostPosted: Sun Feb 08, 2004 5:13 am
Superlite wrote:
....Any input appreciated on what colors, or finish you guys would like on them. Thinking a black anodized spider, aluminum hardware to match, and the crank arms either bead blasted, or natural ti. Polishing could be done to individually for extra, or I could have the cranks coated in a few different colors in large quantities for a minimal charge....
Black, silver or pewter anodized spider; aluminum hardware to match; natural ti arms with SUPERLITE engraved in Swis721 LtEx BT face, further expanded by 10 pts; engraving color to match spider color.
What's the spider BCD, 130 or 135?
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Sun Feb 08, 2004 8:11 am
Here's the axel it will use, weighs a scant 80g. Considering it goes through both cranks and holds the spider it is very light. Still trying to determine which grade of aluminum to use, whether 2000 or 7000 series.
File comment: Massive diameter hollow aluminum axel, super stiff!
 Post subject:
PostPosted: Sun Feb 08, 2004 8:50 am
I'm thinking about stiffness: how stiff will it be compared to all those new high-end carbon crancks which weigh the same as your combo.
I guess you'll use hollow crancks - stiffness? How will you test this?
Is the 450 g weight including the outside bearings or not?
These are just some question I have, but I hope your project will be succesful.
 Post subject:
PostPosted: Sun Feb 08, 2004 8:52 am
Like I said, sub 450g for crankset, BB combo. Stiffness should be very high and it will be tested in a lab for deflection over a load, same as velonews test. That way you can see how they compare.
 Post subject:
PostPosted: Sun Feb 08, 2004 9:08 am
I just couldn't believe it, 80g for the axle, let's say 50 for the bearings etc, so the crancks will weigh around 320g :shock:
 Post subject:
PostPosted: Sun Feb 08, 2004 5:17 pm
Add the shell, not much....wow!
Superlite what is the drawing program you're using?
Have you drawn the whole thing yet in exploded axo?
 Post subject:
PostPosted: Sun Feb 08, 2004 8:11 pm
I'm using Autodesk Inventor. Look in the upper left hand corner. :wink: I have the exploaded view of the assembled crankset, but I won't show that yet. Theres still a few minor changes to be made, depending on the source for the titanium tubing, and which method I use to get the correct q-angle, either bending the tubes, or cutting slplines at an angle.
And Joel, don't second guess and be dissapointed, I doubt I could get it to 320g crankset/BB combo. Although that would be nice. :D
 Post subject: Superlite crankset
PostPosted: Sun Feb 08, 2004 10:41 pm
Hi,this looks like a fantastic design,must say though,your spline design looks very similar to the right hand arm interface on a set of sweetwings cranks I'm using?Don't here much about theas cranks on this forum,why is that?they are very light and stiff,and from my experience,very reliable.
Ti or dye!
 Post subject:
PostPosted: Sun Feb 08, 2004 10:56 pm
Sweetwings? What the hell are those? :lol: How much do they weigh? I'm guessing not very light or they would be talked about much more. Got a link or pics?
 Post subject: Sweet wings
PostPosted: Mon Feb 09, 2004 12:50 am
You guess wrong,520g!Sweet Wings are a two piece crank design with outboard bearings,very much like new DA,and it can be dissasembled using only one M10 allen bolt.Attached is a set I've got on my CAAD5,plus some scans of original sales literature.
Ti or dye!
 Post subject:
PostPosted: Mon Feb 09, 2004 1:23 am
yeah, sweet wings used to be THE baddest cranks around...I might be mistaken but i think at one point they did produce a tubular TI crank that was lighter than the cro-mo ones. I heard that there were problems withe the outboard bearings (at least in the offroad version)
 Post subject:
 Post subject:
PostPosted: Mon Feb 09, 2004 1:33 am
Nice, seems pretty nice. Mine are gonna take it up a notch tough. Definatly will be much stiffer, and lighter to. :wink:
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Caad10 sub 7kg with Vector 2 Project
sgergole
Tue Feb 14, 2017 4:30 am
nemeseri View the latest post
There are no new unread posts for this topic. 2017 Supersix Evo (non HiMod) WW project
mikey168
Fri Mar 10, 2017 11:35 am
Beaver View the latest post
There are no new unread posts for this topic. Climbing bike project ideas....!!!
[ Go to page: 1 2 3 4 5 6 ]
Neckkoss
82
5745
Wed Mar 15, 2017 12:08 pm
Neckkoss View the latest post
There are no new unread posts for this topic. Shimano E-Tube Project - Older Versions
gustavocarvalheira
Fri Dec 02, 2016 11:01 pm
androidavies View the latest post
Users browsing this forum: Baidu [Spider], beeatnik, Bing [Bot], Google Adsense [Bot], mattinnc, micky, mile2424, Mockenrue, NiFTY, shimmeD, stormp, SyDo, Yahoo [Bot] and 34 guests
