It is currently Sat Apr 29, 2017 6:45 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Jan 31, 2014 8:43 pm
I'm wondering about how to replace Garmin magnets (speed/cadence sensor)... I found Icarus magnets on Ebay:
https://www.facebook.com/IcarusCycling
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
Of course every neodymium magnet will work and will be probably cheaper....more:)
I found also this:
http://www.tokencycling.com/products.ph ... _parent=62
so do you know if EPS magnet will work with Garmin sensor?
PostPosted: Fri Jan 31, 2014 8:57 pm
Hey I have used the magnets that go on the axle. My tip - use some sort of rubber glue with the magnet. I have had mine come off, even really strong ones that were only attached by magnetic force. I used some sort of rubber glue (just a small amount) like shoe goo which holds tight, and it peels off cleanly too. The magnet plus the glue keeps it locked in place. You can get magnets in 10 packs for like five bucks at hobby and craft stores.
PostPosted: Fri Jan 31, 2014 9:22 pm
http://www.rare-earth-magnets.com/p-58-nsn0814.aspx
https://forums.garmin.com/showthread.ph ... (neodymium)-magnet-to-replace-the-GSC-10-crank-arm-magnet
I used some silicone to keep the magnet from moving around too.
PostPosted: Sat Feb 01, 2014 12:26 pm
Administrator
If you need one of the round magnets that goes in the pedal insert I have one in black. PM me and its yours.
RESIDENT GRUMPY OLD MAN.
PostPosted: Sun Feb 02, 2014 1:46 am
Has anyone found a source for magnets shaped similar to the icarus spoke magnet? I haven't had any luck, but I can't imagine they have a supplier that makes them in that shape specifically for them.
There are no new unread posts for this topic. Pioneer cadence magnets
BdaGhisallo
Thu Nov 24, 2016 4:25 pm
silvercivic27 View the latest post
There are no new unread posts for this topic. Garmin 2S experiences?
Shrike
Thu Aug 04, 2016 2:33 pm
Shrike View the latest post
There are no new unread posts for this topic. D-Fly and Garmin 1000
superbikemike
Fri May 13, 2016 6:54 pm
goodboyr View the latest post
There are no new unread posts for this topic. New garmin mount :o
BigCol
14
2512
Fri Aug 19, 2016 6:25 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Garmin Edge 500
Andrewjn
Fri Oct 28, 2016 2:24 pm
3Pio View the latest post
Users browsing this forum: alistaird, Bing [Bot], James0133, lamphead and 35 guests
