Carbon Front Derailleur Clamp Stiffness?
esfrost
by esfrost
Hey there!
As the title says, i was wondering about the stiffness of a front carbon derailleur clamp (in size 34.9mm)... I read that they tend to be flexy under load, which can make the front shifting to the big ring kinda hard... I have a carbon frame, and i'd like to protect it by using a carbon derailleur clamp. I did a search on the forum for this question, but could not really find any satisfactory answer, maybe there's none, but let's see!
So, anyone using this type of carbon clamp in 34.9mm, please, shed some light on this!
Thanks!
Beancouter
by Beancouter
One of my friends used one ( was a parlee clamp on a caad) and it snapped.
Having looked myself for my latest build, I didn't bother. From my research, the simple carbon bands (eg mcfk) have very tight tolerances and you should order the one that is
perfect for your actual frame (ie a band sold as 34.9 will not necessarily fit perfectly at the correct torque). There are now adjustable carbon ones, but I thought they were fugly!
Juanmoretime
Administrator
by Juanmoretime
I've been using the Parlee clamp for over two years with a Record front braze on derailleur. Shifts perfect and no issues. I'm also using an alloy bolt to hold everything together. I can see someone having a stiffness issue using the old Sram Red titanium caged derailleur but then the issue would be the derailleur not the clamp.
RESIDENT GRUMPY OLD MAN.
TimmS
by TimmS
I'm using a mcfk clamp for 3 or 4 years now.
Not problems at all, there is more flex in the derailleur (Force) than in the clamp!
shoemakerpom2010
by shoemakerpom2010
I bought a parlee clamp on this board 34.9 for my SystemSix and the shifting is no affected at all.
esfrost
by esfrost
Thank you guys for all the help! I've ordered a carbon clamp and will see how it works! Thanks!
bikewithnoname
by bikewithnoname
I have a Parlee one on my Parlee (surprising I know) I don't notice any flex whatsoever
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
nickf
by nickf
I have been using the omni racer carbon clamp for about a year with no issues. Installed on a caad9 with a sram red fd. Seems to shift fine. I'm in the big ring most of the time. No hills in Florida. I see no visible flex when it's on the stand. Check them out on eBay.
Butcher
by Butcher
I too use a Parlee version. Originally with a SR11 and now with a SR EPS [with the derailleur stiffening piece] and I never thought I had a problem. I always wondered if I would before I bought it.
Dammit
by Dammit
I killed one of the eXotic ones really fast with Di2.
excremanwu
by excremanwu
I am using that from Parlee and x cross (copy cat from PRC?) with 7900 and 9000, both fine without any problems
esfrost
by esfrost
Just got the clamp on the mail. Looks better than in the photo... You just simple open it up, and slide it onto the tube?
Juanmoretime
Administrator
by Juanmoretime
Yes, that is correct.
esfrost
by esfrost
Okay, thanks. Will see how it fits, and works, and let you guys know...
Butcher
by Butcher
FYI, With my Parlee, they also gave me a piece of plastic clear tape to 'shim' the clamp due to the minute size differences of the tube. I still had issues with the clamp slipping. Cloth tape worked much better and it had never slipped since then.
