It is currently Mon Jan 22, 2018 3:18 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 31, 2014 5:36 pm
Unless you are specifically buying the wifli rear derailleur, its a short cage.
PostPosted: Fri Jan 31, 2014 6:00 pm
Thanks. Some online shops are selling the standard with short or medium cages, so that's why I was confused. I guess they're wrong.
6.24kg CAAD10
PostPosted: Fri Jan 31, 2014 7:03 pm
Wi-Fli definately has a long cage, but most people running wi-fli would probably do so knowingly, for cyclocross or unique drivetrain requirement where you want a 32T rear cassette. I'm not aware of Medium vs Short Red cages, though I see Wiggle sells "Medium" but it's WiFli... to me, WiFli = long. A WiFli backplate definitely isn't compatible with Fibre-Lyte backplates (currently) and I have no idea about the Red22 compatibility.
The older 10sp Red derailleurs have a slightly different cage shape than the AeroGlide version (new 10sp Red). The new red has a subtle squared-off profile and the cage tab on the new Red is attached to the front plate, rather than the back plate with the old Red. At least when I bought my last Fibre-Lyte plate, they were all modeled off the old Red and the standard FL included a cage tab on the backplate (super lite version does not, can be handy though).
Therefore, installing the FL plate on new Red means removing the cage tab. This will also leave a weird carbon piece sticking out that is no longer needed. It'll work fine like this, but it looks more polished if you can file that piece down.
Old Red (no modifications to FL plate)
New Red (with modifications to FL plate)
Sorry to offend with my ride-it-until-it-implodes winter chain and cassette.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
Strava: Wayward Cyclist
PostPosted: Fri Jan 31, 2014 10:52 pm
Thanks for that! All makes sense now. I really appreciate the info.
Is the tab on the FL plate easy to remove? Just it just slide off?
6.24kg CAAD10
PostPosted: Fri Jan 31, 2014 11:08 pm
There is a small screw that holds the round tab onto the plate. Remove that, then file the tab extension down until it meets up with the front plate tab.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
PostPosted: Fri Jan 31, 2014 11:10 pm
Perfect. Thanks again.
6.24kg CAAD10
PostPosted: Fri Jan 31, 2014 11:25 pm
For some reason I couldn't access this thread until now. The mech plate that is shown in the photo is indeed designed for the 'old' Force/Red. We do have the later Force/Red plate (called 2013 model on our website) which doesn't have the chain jump stop because as mentioned, the outer plate has it. I'm told that plate also fits the 22 models but I need to check that out in person. Visually I'd say that it does but I haven't test fit yet. We do also have the Wifli plate in stock but it isn't on our website yet, but should be soon. As far as I'm aware, there is only the short cage for 22 / 10 speed and wifli 10 speed on the current models but I could be corrected.
Fyi, if riders want the older Red/Force plate modifying to remove the jump stop and also shortening we'd be happy to accommodate, we just need a little info on how the mods are required.
PostPosted: Fri Jan 31, 2014 11:34 pm
Good to get it straight from Stephen. Nice to see he's got plenty of configurations now.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
PostPosted: Sat Feb 01, 2014 12:04 am
Thanks Stephen! A lot of great info in this thread.
6.24kg CAAD10
There are no new unread posts for this topic. SRAM Red Front Derailleur Tuning (YAW)
prendrefeu
Wed Jan 10, 2018 12:45 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Sram red rear derailleur issues
NiFTY
19
2392
Tue May 09, 2017 11:32 pm
Gearjunkie View the latest post
There are no new unread posts for this topic. SRAM etap rear derailleur
aerozy
10
862
Fri Nov 17, 2017 3:06 am
charlieboy52000 View the latest post
There are no new unread posts for this topic. Sram etap rear derailleur problem
srammer
Sat Jan 20, 2018 10:57 pm
wingguy View the latest post
There are no new unread posts for this topic. nvroadie's Red Derailleur- Need all your crazy tuning ideas!
nvroadie
Thu Mar 16, 2017 9:53 am
Marin View the latest post
Users browsing this forum: BikeAnon, Bing [Bot], Catagory6, dbnm and 24 guests
