It is currently Fri Aug 18, 2017 9:33 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Sat Jan 25, 2014 5:55 pm
I did some searching and couldn't find answers.
I'm going to tune the current version of the SRAM Red RD with Fibre-Lyte mech plate and pulley wheels, but I'm not sure about a couple of things.
For the mech plate, does it matter which size cage the RD has? The Fibre-lyte plate doesn't seem to come in different sizes, and the SRAM site doesn't list different cage sizes, but a few places selling it offer short and medium cages. Not sure if of the fitting here.
Also, the jockey wheels come in 10t and 11t. I think the stock wheels that come in the RD are 10t, so does it matter which size I get, or I have to get the same size as stock?
6.24kg CAAD10
PostPosted: Sat Jan 25, 2014 6:24 pm
the size of the cage depends only if you are planning on running really big cogs in the back.
Like a 12-27 ideally should be using a longer cage. If you run an average size cassette (11-23, 12-23, 12-25 etc) a short cage should be fine. Also the jockey wheels are kinda moot point. The theory is a 11t spins slightly less than a 10t rear cog and thus saves on power (less power loss). It's negligible.
The one important thing to note for jockey wheels is match the design with the original one. I can't remember sram derailleurs, I never bothered to take my apart. But for Shimano the top jockey wheel is designed to have side to side float. Some aftermarket jockey wheels don't have this float make messes up with the shifting a bit.
http://www.hackracer.com/
PostPosted: Sat Jan 25, 2014 6:29 pm
Thanks. So the cage length has no affect on the size of the mech plate? Basically the Fibre-Lyte plate will work with any size cage?
The jockey wheels do have lateral float, so it should be fine.
6.24kg CAAD10
PostPosted: Sat Jan 25, 2014 6:40 pm
I would email Fibre-Lyte and ask them directly. Are you going to replace both the inner and outer cage with Fibrelyte parts? Stephen from Fibre Ltye sometimes frequents the forum. But best to ask them directly.
PostPosted: Sat Jan 25, 2014 6:42 pm
Measure the distance between the jockey wheels. Fibre-Lyte states 55mm for the Sram Reds.
PostPosted: Sat Jan 25, 2014 6:43 pm
I would, but I don't have the RD yet. Want to make sure I get the correct parts before getting them.
6.24kg CAAD10
PostPosted: Sat Jan 25, 2014 6:46 pm
Didn't even know they made an outter plate. I have only seen the inner plate.
6.24kg CAAD10
Just wait till you you get the mech then. Save a lot of trouble.
PostPosted: Sat Jan 25, 2014 6:48 pm
Yeah, I definitely can, just figured someone on here has done this tune and would know.
6.24kg CAAD10
PostPosted: Sat Jan 25, 2014 6:54 pm
Are you talking about Red 22? According to the Sram site there are only 2 options for the RD, the standard and WiFli (long cage). All 3 Fibre-Lyte Red cage options are for the standard cage version (55mm).
PostPosted: Sat Jan 25, 2014 7:16 pm
I'm talking about the standard Red RD, not 22 or WiFli.
6.24kg CAAD10
PostPosted: Sat Jan 25, 2014 7:29 pm
My previous post applies to Sram Red 2012 as well.
BTW the jockey wheels have 11 teeth.
PostPosted: Sun Jan 26, 2014 2:34 am
I mounted the Fibre-Lyte back plate to current generation 10sp Red and it worked very well. I took off the knob from the fibre-lyte (which was more for the previous generation Red) and then used a dremel to make the back plate look identical to the front.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
Strava: Wayward Cyclist
PostPosted: Fri Jan 31, 2014 6:50 am
Any photos of what you did and more info as I'm keen to try to do similar to my red RD?
Cheers baz
PostPosted: Fri Jan 31, 2014 2:10 pm
Thanks for the jockey wheels size, but still confused about he derailleur. So the current standard Sram Red RD only comes in a short cage?
6.24kg CAAD10
There are no new unread posts for this topic. Sram red rear derailleur issues
NiFTY
19
1632
Tue May 09, 2017 11:32 pm
Gearjunkie View the latest post
There are no new unread posts for this topic. Sram etap rear derailleur problem
srammer
Tue May 30, 2017 4:25 pm
sungod View the latest post
There are no new unread posts for this topic. nvroadie's Red Derailleur- Need all your crazy tuning ideas!
nvroadie
Thu Mar 16, 2017 9:53 am
Marin View the latest post
There are no new unread posts for this topic. SRAM eTAP Tuning?
ProfessorChaos
11
2463
Sun Nov 27, 2016 12:07 pm
ProfessorChaos View the latest post
There are no new unread posts for this topic. Campagnolo Chorus HO Rear Derailleur
stormur
Mon Aug 07, 2017 11:30 pm
ultimobici View the latest post
Users browsing this forum: Baidu [Spider], bremerradkurier, Google Adsense [Bot], ironhayden08, itsacarr, mike001100 and 52 guests
