Inline Adjuster hot or not
User Name
by User Name
I don't trust them, coz the ones I've had keep loosening, so I only use them on front derailleurs. I use cheap ones, so I dunno if that makes much of a difference.
I still have "clothesline" gears (7800 and 7700), so perhaps the movement from steering causes them to twist.
Either way, it doesn't bother me, coz it's too easy to tighten the FD while riding.
I forgot to put one on my old Carbon Soloist, and it's been working fine without one. :mrgreen:
by DWatkinsBSB
Hot for TT bikes with hidden rear brakes.
Very handy when I am adjusting my rear brakes between the training wheels and the firecrests on my Felt DA.
by efeballi
I have inline adjusters for both derailleurs. If you have a flat rear tire when racing, the new rear wheel may be mounted a little crooked during the wheel change as time is critical. I have no time to check the gear adjustment while stopped so I do it when I'm trying to catch the group.
This is enough reason to keep the adjusters IMHO.
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
by tinozee
Adjusters not hot. Just get it right the first time.
The Felt could be hot without that eagle beak of a saddle.
by tinozee
by Twinning
tinozee wrote:Adjusters not hot. Just get it right the first time.
Sorry about the saddle. Don't like numbness in my junk. Fizik feels like sitting on a pole. Might as well just not use a saddle and sit directly on the seatpost.
by deek
upside wrote:You will need a in-line barrel adjuster with the Yaw derailleur and the 9000 Dura Ace. You need to really ratchet up the tension to get those to work like they should. I have used Sram and Jagwires...and those work nice and are quite small.
This guy is spot on. It is a total PITA to get the cable tension high enough without the adjuster. Your housing will eventually seat itself and you'll lose more tension and have to start the process over again without the adjuster. Totally worth it.
by carbonLORD
I use a Park tools 4th hand tool, the BT2 Cable Stretcher when needed. Great for brakes and derailleurs.
by Wookieopolis
I'm with carbonLord on this. I use a 4th hand/cable puller and can get more than enough tension on a Yaw derailleur with no need for an inline adjuster. The right tool makes it easy to get the job done right the first time.
by Svetty
Never had the need for an in-line adjuster - it just needs a little finesse when installing the cable. TBH the adjuster's only real purpose is to compensate for less than optimal wrenching :oops:
by eric
Or perhaps you are more tolerant of poor shifting.
by Twinning
eric wrote:Or perhaps you are more tolerant of poor shifting.
Haha true that. The minimal weight added/ loss of aerodynamics from an inline adjuster will cost you less time in a race than dropping a chain from an improper shift.
by tinozee
Twinning -
Haha @ just mount the post. No, I hear you about the saddle, but I had to deliver the honesty in the "hot or not" context. The bike looks fast as all hell. I will save you from showing you a distance bike I have with an Adamo saddle. Also, I think the Felt/Sram combo is a personal taste thing. It screams "USA" to me, whereas many euro bike types only accept campy and made in italy frames. To each his own, I like both. And on the road in motion, fast as hell looks the best.
by andybarnes
Not. I had cable friction issues with Jagwire inline adjusters on a Super-Record rear derailleur set up. Removed the adjusters and the problem improved. I don't use it on the front derailleur either. It is possible/easy to set up perfectly without if you spend a little time on it.
by shimmeD
No, not cool for weightweenies to have in-line adjusters.
I removed my on-frame barrel adjusters to save weight, and my current ride has been built without.
Front does not need adjustment and fine-tuning is done at the rear deraileur.
Less is more.
