It is currently Tue Jan 23, 2018 1:27 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Jan 24, 2014 12:35 pm
I want to install some new cables on my cannondale supersix.
I am running Sram force with a red yaw front derailleur.
Is it recommend to install inner adjusters? Now I have but I never use them. But probably it is easy when you do the setup.
What is your opinion?
PostPosted: Fri Jan 24, 2014 5:45 pm
For the front you need an in line adjuster if you are going to have any way to adjust the cable tension besides loosening the clamp and repositioning the cable. That's a difficult way to get the adjustment just right.
I'd recommend at least an in line adjuster for the front. Since the rear derailleur has an adjuster on it, an in line adjuster just means that you can adjust the cable while riding. I like that in case something goes out of adjustment or just needs fine tuning during a race. But my current bike doesn't have it and I haven't missed it much.
PostPosted: Fri Jan 24, 2014 5:52 pm
My bike has an inline adjuster for the front derailleur which you can see and also a quick release/ inline adjuster for the rear brake which is hiding behind the stem. Is my bike hot?
PostPosted: Fri Jan 24, 2014 7:24 pm
I went without an inline-adjuster on my SRAM-RED-YAW, and it took a lot of adjustment to initially get it right. I think I readjusted about a half a dozen times in the first week to get it "perfect". But since then it has been holding (about 9 months now) It does make me nervous.
PostPosted: Fri Jan 24, 2014 11:25 pm
Once the cables have stretched I've rarely had the need to adjust during a ride, so no. Plus they don't look good.
2015 S-works Tarmac DA9000, 6,29kg
PostPosted: Sat Jan 25, 2014 9:32 pm
Twinning wrote:
Is my bike hot?
Not to my eyes but YMMV ;)
PostPosted: Sun Jan 26, 2014 2:47 am
Twinning wrote:
Is my bike hot?
... any bike with SRAM is very un-hot.
I would go with in-line adjusters for both gear cables; they are very functional and convenient.
PostPosted: Sun Jan 26, 2014 10:14 am
Twinning wrote:
Is my bike hot?
If you have to ask.... :noidea:
I believe that bicycles do not put enough force on the shifting cable that it is possible to stretch, but I do believe that housing compresses.
That said, I do not use those barrel adjusters as you can adjust when necessary without them, using your rear derailleur. It's rare I'll ever adjust my FD as I never use my FD.
Or, get Di2/EPS and leave replacing shifter cables and housing behind, indefinitely.
Oh and my bikes are hot. (Statement VS question) :beerchug:
carbonLORD.com
PostPosted: Sun Jan 26, 2014 3:37 pm
it looks more like a tt bike with a dropbar
PostPosted: Sun Jan 26, 2014 3:53 pm
It's hot, there is always a bit too much jealousy around here. :up: :up: :up:
PostPosted: Sun Jan 26, 2014 4:04 pm
Ha thanks. I was just trying to make a point that you can barely notice an inline adjuster.
PostPosted: Sun Jan 26, 2014 4:50 pm
I've found mine very easy to use. Instead of reaching down towards the frame to make adjustments, they are closer to the bars and stem. Jagwire makes them in lots of colors also. I go with hot.
PostPosted: Sun Jan 26, 2014 5:04 pm
All the ones I've had to work on have slipped out of adjustment over time. Making them necessary.
My bikes, whilst not hot, don't seem to need anywhere near as much adjustment. Typically a couple of goes at clamping the front mech and all is fine
PostPosted: Sun Jan 26, 2014 5:10 pm
Just had a look at jagwires latest offering, look like a bit of thought has gone into them!
PostPosted: Sun Jan 26, 2014 6:38 pm
You will need a in-line barrel adjuster with the Yaw derailleur and the 9000 Dura Ace. You need to really ratchet up the tension to get those to work like they should. I have used Sram and Jagwires...and those work nice and are quite small.
There are no new unread posts for this topic. Inline barrel adjuster needed?
addictR1
9
775
Thu Aug 31, 2017 7:18 am
addictR1 View the latest post
Users browsing this forum: Baidu [Spider], Exar, morganb, Spinnekop, stormur and 38 guests
