Eiffel Bike
CarpetFibre
by CarpetFibre
Did someone already post this? Thought it was pretty cool...
Link
Geoff
by Geoff
Nice find. A full isotruss bike. Pretty neat.
jekyll man
by jekyll man
Official cafe stop tester
dvincere
by dvincere
I wonder how it would hold up in the wind tunnel.
bazmac
by bazmac
Geoff wrote:Nice find. A full isotruss bike. Pretty neat.
I can't believe that they did not deck it out with the M5 brakes as they would be a perfect match. Amazing amount of work but still a fair bit heavier than the top shelf frame sets.
Cheers baz
Devon
by Devon
But why? It's not even vaguely light...
Campagnolo; because it's a bicycle, not a fishing rod.
justinn
by justinn
^ maybe stiffer?
Devon
by Devon
True, but can you honestly tell me you, or more regular cyclists, would notice this very slight difference?
Obviously it's a concept, but in the real world it has very little practicality.
neeb
by neeb
It would be interesting to have the stiffness figures - obviously it's moderately heavy for a carbon frame, but let's say it turned out to be 50% stiffer than a standard high-end modern frame. Then perhaps it would be possible to build something similar that was lighter and also as stiff as modern frames.
But I strongly suspect that this isn't the case - different construction methods are better suited to different purposes and different materials, and suspect that this is a very suboptimal construction method for making a carbon bike frame. Presumably it's also suboptimal for making a steel frame, otherwise we would have had micro-trussed bike frames for years instead of ones made out of thin butted tubing.
I'm not an engineer, but I suspect that the reason this doesn't work is that the trusses are on the wrong scale for the application - a bike frame already is a rigid structure made of two open triangles, but by breaking those down into hundreds of smaller triangles you are just adding redundant complexity, which is bound to introduce functional inefficiency.
Looks cool though.
justinn
by justinn
Devon wrote:True, but can you honestly tell me you, or more regular cyclists, would notice this very slight difference?
I have no argument there, but since when has the cycling community, especially one concerned with dropping grams off of the weight of bikes by any means necessary, been concerned about practicality?
