It is currently Thu Jan 18, 2018 11:23 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Mon Jan 20, 2014 5:27 pm
New frame coming and new Deda 35 mm handlebars to go on it and need a Garmin mount to fit these O/S bars as the standard clamps for 31,8 bars are too small , I Came across the raceware direct model which uses the 3 d printing method but was wondering if there any other offerings out there .
Tia
PostPosted: Mon Jan 20, 2014 7:11 pm
Have you looked at the K edge mount that fits under the top cap like an upper spacer? I really like mine, although I'm using it with a Wahoo RFLKT.
PostPosted: Mon Jan 20, 2014 7:23 pm
Last I looked the Raceware mount was arguably the best one. It's light, holds the garmin securely yet does not break off the delicate tabs, and keeps the unit close to the bars and level with the bars like an SRM head unit. It's in your field of vision (since it's in front of the bars) yet not sticking up into the wind or sticking out visually. Even though it is 3d printed it's strong and not brittle.
PostPosted: Mon Jan 20, 2014 11:47 pm
+1 for the raceware
PostPosted: Tue Jan 21, 2014 12:16 am
+1 im using it for 4 months plus
PostPosted: Tue Jan 21, 2014 12:40 am
Tillquist
carbonLORD.com
There are no new unread posts for this topic. Advice on 31.8mm or 35mm bars that fit Shimano Hydro hoses through.
nealjp
Wed Jan 17, 2018 7:09 am
nealjp View the latest post
There are no new unread posts for this topic. Quick question: Are Deda 31.7mm bars OK with non Deda stems?
hannawald
Fri Oct 20, 2017 10:41 pm
hannawald View the latest post
There are no new unread posts for this topic. K-Edge Garmin Mount - Regular vs XL
ipenguinking
9
833
Thu Dec 28, 2017 7:22 pm
dim View the latest post
There are no new unread posts for this topic. Deda SuperZero and Garmin
jbrandt
21
3052
Mon Jun 19, 2017 3:59 pm
5 8 5 View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
Users browsing this forum: Bing [Bot] and 37 guests
