It is currently Wed Jan 24, 2018 8:52 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sat Jan 18, 2014 2:27 pm
just finished putting together swift carbon neurogen TT bike with shimano da 7900 (16.4 lbs)
is there anyway of adjusting the bar end shifter such that when riding in 11 or 12 rear gear, the bar end does NOT point straight down to the ground..........but points straight out??? I've screwed around long enough with the internals, need some expert advice. thanks
PostPosted: Sat Jan 18, 2014 2:40 pm
I've not got any experience of messing with the internal parts of these shifters. But previous experience of both DA and Sram TT shifters is that this is just how they work. If you require the shifters to be level with the ground I think the easiest option would be the Sram return to centre shifters. Or indeed an electronic setup.
PostPosted: Sat Jan 18, 2014 4:30 pm
Zipp makes a shimano compatible R2C shifter.
http://zipp.com/bars/vukar2c/
PostPosted: Sat Jan 18, 2014 8:08 pm
In short.......no. the lever requires the whole range of movement to cover the gear range.
You could invert them so the lever is pointing up and slightly backwards, that's about it.
Pedalling Law Student.
There are no new unread posts for this topic. R785 vs R9170 Shifters
NJCyclist
25
2106
Wed Aug 23, 2017 5:39 pm
ms6073 View the latest post
There are no new unread posts for this topic. SRAM Force 22 vs Red 22 shifters
loudtiger
10
1039
Mon Aug 14, 2017 4:07 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. Wonder how much the new SRAM shifters weigh
fromtrektocolnago
Mon Apr 03, 2017 6:53 am
RussellS View the latest post
There are no new unread posts for this topic. Di2 one or two button timetrial bar end shifters?
htc
7
589
Thu Jan 26, 2017 2:48 pm
audiojan View the latest post
There are no new unread posts for this topic. Does XT di2 fits to Ultegra di2 shifters [11 sp]
johancoenen59
Thu Jun 01, 2017 2:36 pm
PinaRene View the latest post
Users browsing this forum: alcatraz, pdlpsher1 and 24 guests
