It is currently Sun Jan 21, 2018 2:07 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Jan 17, 2014 7:19 pm
I have a sram red 2013 on my cervelo s3 (2010) and I noticed my bikestore, who installed the group, did made some mistakes:
- my right crank arm is hitting my front derailleur when the chain is on the big chainring because the big chainring it to far to the outside (on the photo the chain is on the big front chainring and the smallest rear chainring) In addition to this problem: the chain is also getting off the big chainring on my crankarm when I push my (left) shifter (just a bit) too hard.
- Now I wanted to adjust the derailleur by adjusting the ''high limit screw'' (correct?) but I think the cable routing isn't correct.
My questions are:
- what do you think is wrong with the current setup?
- is the ''damage'' any big on my frame? Is it worth going back to the bikestore?
- how can I fix this?
Thx in advance
cerv2 by rgrhg, on Flickr
cerv1 by rgrhg, on Flickr
PostPosted: Sat Jan 18, 2014 12:39 am
Hello,
Not sure exactly what is wrong with the setup should have the bike shop who built it address the issues.
As for the carbon I can help.
We do carbon frame repairs as well as custom parts and if you are looking to have your fame repaired let us know.
Thanks
Ric R
www.concept2composite.com
PostPosted: Sat Jan 18, 2014 12:50 am
Riccfs wrote:
Hello,
When you look at my first photo you can see the cable has cut itself a little bit into the frame. Do you think it is neccesary to repair this to prevent futher damage?
I hope you can answer on this as an expert, I do live in Europe so I have to thank for the offer in any case..
PostPosted: Sat Jan 18, 2014 2:49 am
1/ You need to adjust the H Limit screw so that the front derailleur does not move so much to the outside.
2/ You need to check the routing of the cable. Does it thread through the frame properly? A bit of cosmetic damage where the cable exits the hole in the frame should not matter - you sometimes get a little damage where the cable rubs on the outside of the hole.
PostPosted: Sat Jan 18, 2014 4:31 am
http://www.artscyclery.com/learningcent ... leurs.html
You might need to check the angle of the cable coming into the derailleur, either in front or from behind the bolt, not sure what the sram standard is
There are no new unread posts for this topic. Dura Ace 9100 front derailleur installation problems - can't shift into big ring
eric01
Sun Sep 24, 2017 5:36 pm
mlok View the latest post
There are no new unread posts for this topic. Campagnolo EPS installation on Colnago C60 frame
torinb
29
1934
Mon Aug 07, 2017 4:08 pm
joeyb1000 View the latest post
There are no new unread posts for this topic. Could a rim cause this sort of damage to a tube and tyre? [PIC]
Shrike
29
2124
Fri Feb 03, 2017 10:49 am
tarmackev View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo Chorus rear caliper stone damage??
Boshk
7
522
Tue Jan 16, 2018 2:14 pm
Boshk View the latest post
There are no new unread posts for this topic. Need weight advice from Supersix Evo pros - Is something wrong?
alexgodmar
20
1195
Tue Dec 26, 2017 11:19 pm
alexgodmar View the latest post
Users browsing this forum: alcatraz, Bing [Bot], fromtrektocolnago, moyboy and 37 guests
cron
