The Great Long Drop Brake Debate
Dov
by Dov
Why oh why do they not release new group sets with long drop brakes???
I know there are options: Shimano Ultegra, TRP R957, Grand Cru but none of these are gonna look good with DA9000
Are there any ways around having to not break a group set for after-market long drop brakes?
Felt F1 DA Di2
Cinelli Supercorsa
Cielo Classic Sportif
Concorde Shopper
Nagasawa Fixie Skid Machine
Cannondale CAAD 10 Track [custom]
Employee of Rapha
Instagram
Strava
MajorMantra
by MajorMantra
In short, no. Not that I'm aware of.
I wonder if someone could engineer a brake shoe that fits standard calipers, but extends the reach.
knef
by knef
Such a brake shoe exists. I've seen it somewhere.
MajorMantra
by MajorMantra
Cool, I did not know that existed.
DMF
by DMF
I have the BDop, it's actually a very nice piece of quality kit. Recommended.
kulivontot
by kulivontot
Why?
HillRPete
by HillRPete
How much extra reach do you get out of the extenders? Thought they just gave a few extra millimeters, to get to the lowered brake tracks of some carbon clincher?
Also, I'd really just run dedicated medium/long reach brakes, before resorting to such a hack. The TRP RG957 looks very nice, actually.
DMF
by DMF
Really more of a hack to use 1:3 brakes with 1:4 pull ratio levers... My BDop is 5mm offset.
I've used it to mount a KCNC C7 to a frame that only takes long reach brakes.
Rick
by Rick
I took a dremel to the adjustment slot of some Dura Ace 7700 series brakes so I could use them with 700c wheels on a 27" frame.
They work fine. I probably extended the slot 4-5 mm
Valbrona
by Valbrona
Modern bikes designed with clearances to take fenders do not all fall into the same category these days. Rather than making significant changes to geometry, frame designers typically introduce small amounts of clearance by raising the brake bridge at the rear a little and adding just a small amount of extra length to the fork legs. This means that regular close clearance brakes still tend not to have enough drop, but the large amount of drop provided by deep-drop brakes is sometimes unnecessary.
Point being ... the small amount of extra clearance offered by the B Dop extenders might be just enough to allow the fitting of fenders. But it depends on the frame in question.
basilic
by basilic
Rick wrote:I took a dremel to the adjustment slot of some Dura Ace 7700 series brakes so I could use them with 700c wheels on a 27" frame.
Rick, would you show us what you did? a picture of a caliper arm without the brake pad? thanks in advance
solarider
by solarider
The advent of disc brakes means that not many manufacturers will now invest in nice long drop brakes unfortunately.
The bikes for which they are intended (tourers, gravel bikes, winter trainers etc) that need fenders and hence clearance will now become disc brake by default as new models are released.
Rick
by Rick
From the scuff marks on the arm you can see where the "normal" positiuon of the pads were. I elongated the slots until it was just enough to use on my 700c wheels.
There must be some parallax effect in the photo, because the pads actually line up with the rim on the bike, at least when clamped.
This bike was built for 27" wheels in about 1980 and you can see it has fenders attached. I just couldn't bring myself to scrap a good frame, so I converted it to a winter commuter.
Svetty
by Svetty
knef wrote:http://bdopcycling.com/BDop%20Offset%20Holders.asp
I also have these. They work really well giving about 7mm extra drop. In use they are as effective as normal pad holders and are not a bodge at all.
