It is currently Sun Jan 21, 2018 2:03 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Jan 16, 2014 1:08 pm
Hi,
I have always raced on a standard but have recently switched to a compact SRM to keep my rides in control during the off-season. For the reason I need a set of LARGE compact rings to run for the spring/summer.
Right now I am thinking about going 52/38 maybe even 53/39, 110bcd & 11 speed. Stronglight CT2's are my top choice of course but given their hollowed out shape I am nervous they will become floppy at this size. I would rather not have to splurge 170usd on a set of praxis rings if I don't have to. Thoughts, comments and suggestions please!!!!!
Strava
Bicycle1
Bicycle2
PostPosted: Fri Jan 17, 2014 4:38 am
Hi, the praxis rings are excellent, but expensive. You could try strong light and if floppy flog them off for almost what you paid and get the Praxis.
Cheers and good luck.
Baz
PostPosted: Fri Jan 17, 2014 5:52 am
So you bought compact cranks only to then want to put 'standard' tooth chainrings on a 110 BCD? And now worried that the rings will be too flexy?
The logic of this escapes me.
PostPosted: Fri Jan 17, 2014 12:33 pm
This is what I don't understand. Is 50x11 really going to keep your power down significantly?
Edit: if you had no power meter before, then I think I get it.
 Post subject:
PostPosted: Fri Jan 17, 2014 12:38 pm
PostPosted: Fri Jan 17, 2014 1:14 pm
I've been very impressed with my Praxis compact so I'd say them or perhaps a Rotor Aero set (for stiffness).
PostPosted: Sat Jan 18, 2014 2:51 am
I use CT2's, and you know I just wouldn't recommend them at large sizes. Get something with more meat on them.
PostPosted: Sat Jan 18, 2014 4:01 am
It sounds like Rotor Aero or praxis are the way to go. It's a shame the praxis are so expensive but I guess they are worth it.
Strava
Bicycle1
Bicycle2
PostPosted: Sat Jan 18, 2014 9:19 am
Given the praxis rings are drop forged like DA rings yet cost a pair what the DA rings do each I wouldn't say they are expensive. :roll:
Skunkworks Bikes
PostPosted: Sat Jan 18, 2014 1:45 pm
How is $170 expensive? They are bombproof and last. Shifting is perfect. A Dura Ace is twice that.
PostPosted: Sat Jan 18, 2014 4:53 pm
:lol: Expensive in the sense that I can't E.P. them
Strava
Bicycle1
Bicycle2
PostPosted: Sun Jan 19, 2014 2:25 pm
You could also go 52/38t with Specialites TA or KCNC makes the Blade in 53/39t which is stronger than the KCNC K3 Cobweb.
www.royalbicycles.com
There are no new unread posts for this topic. SeatPost for Oversized Rails
TarugoKing
Mon Apr 17, 2017 4:41 pm
TarugoKing View the latest post
There are no new unread posts for this topic. Has anyone successfully modified a saddle clamp to take oversized rails?
alcatraz
Mon Dec 11, 2017 12:21 am
apctjb View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
2015
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. Compact v semi compact
wilwil
35
2539
Thu Jul 27, 2017 11:05 pm
shimmeD View the latest post
There are no new unread posts for this topic. Changing to compact?
Peedee
11
1224
Fri Mar 31, 2017 11:26 am
DJT21 View the latest post
Users browsing this forum: arthurf, Bing [Bot], srshaw and 37 guests
cron
