Chainrings for a Hollowgram Si chainset
Mr_Carlos
by Mr_Carlos
I want to replace the chainrings on my Cannondale Hollowgram Si with some compact ones. Does anyone know what measurements I need, and where is good to buy from (I'm in UK)?
Thanks
hmai18
by hmai18
I've been perfectly happy with my Stronglight CT2 rings, purchased from xxcycle in France.
Mr_Carlos
by Mr_Carlos
Cheers will check them out. Do you have to change the spider to run compact rings?
deltree
by deltree
Yes, you'll need to change the spider to a 110mm BCD version. You'll need a proprietary tool to do this.
hmai18
by hmai18
If you're using a Hollowgram with the 130mm BCD, then yes, you're going to need to change the spider to a 110 BCD to use compact rings.
