It is currently Thu Jan 19, 2017 11:07 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Sun Jan 12, 2014 5:05 pm
Hi,
I'm new to the board (First post) Starting to look at reducing the weight of my bike a bit, I've already changed wheels, cassette, tyres, saddle etc. (Not sure if I can post links up until I have a few more posts)
I've been inspired by some of the rear mechs on here that have received some dremmel action and I fancied giving it a go myself.
I'm running an 11-32t ultegra rear cassette (I know a closer ratio would be lighter but I plan to do Ventoux and I'm no Pantani!) I currently have a 105 rear mech which can cope with the 32t. I plan to have a muck about with this but if there is a mech out there which will cope with the 32T that is lighter to start with then it will be easier. I plan to lose some weight from the front plate and some other areas where I can get a way with it and they run a fibre lute cage and some carbon jockey wheels. If there is no other mech that will do it I will have to try for a very light 105, has anyone done that yet?
Cheers
Paul
PostPosted: Sun Jan 12, 2014 5:14 pm
Hi Paul8v, the Shimano M972 XTR SGS RD (or even GS?) RD should work just fine with 10spd STI levers...
thanks KL :)
PostPosted: Sun Jan 12, 2014 5:32 pm
Thanks KL, looks like it's about 40g lighter than the one I have, is there much that can be done to tune them? Looks like they have a carbon cage already which is good.
PostPosted: Sun Jan 12, 2014 5:33 pm
Other alternative I was thinking, could I fit a longer cage to a Dura ace? Would that achieve a higher rating for the cassette teeth number or are there other factors I haven't considered?
PostPosted: Sun Jan 12, 2014 5:45 pm
I have a buddy with a 10 speed DI2 setup with a long cage derailleur. (Made by K-edge).
I have talked to them. They can do a mechanical Dura-ace with a longer cage too.
I was considering a 9000 derailleur with a long cage.
PostPosted: Sun Jan 12, 2014 5:53 pm
A Dura Ace mech can be made to handle 32T usually. You need to give it lots of "B screw". And fit it with a longer cage, or run a slightly short chain.
But really, going for minimal weight, and having a bike to tear around the mountains are two different chapters in my book.
Good luck.
PostPosted: Sun Jan 12, 2014 6:16 pm
I just fancied it from the point of view that it might be a bit of fun mucking around with the dremmel to make something a bit special (Same as with my car, I'm always tinkering with something on it!) I wouldn't want to remove as much as on that red anodised dura ace one just in case I took off too much and it lunched itself but I think some lightening may be possible.
PostPosted: Sun Jan 12, 2014 6:17 pm
The bike is ridden pretty hard over some badly kept roads so a super light build is out of the question!
PostPosted: Sun Jan 12, 2014 6:19 pm
How much do you weigh?
PostPosted: Sun Jan 12, 2014 6:30 pm
80kgs, I used to do a fair bit of weight lifting, I was 90kg but I've started lifting higher reps of less weight to tone up.
I wouldn't want to go much lighter as I will start to look too thin, I'm not in to the no upper body look!
PostPosted: Sun Jan 12, 2014 7:22 pm
Fitting a longer cage doesn't allow for a larger cassette sprocket, just a larger difference on the front, such as a triple. The deciding factor is the distance allowed between the top jockey wheel and the largest sprocket. The newer RD67 & RD57 mechs have capacity to handle a maximum 30T sprocket, but a 32T may not be ideal unless the hanger on your frame is a little longer or allows the B screw to move the mech enough.
PostPosted: Sun Jan 12, 2014 7:44 pm
Thanks, I figured it might not be as easy as the longer cage, I'm sure I read about people fitting a smaller top jockey wheel to overcome this but I'm not such a fan of that as if anything I would rather fit a larger jockey wheels to help lower friction.
PostPosted: Sun Jan 12, 2014 7:52 pm
thanks KL :)
That is what I am running (the SGS) with 7800 shifters and a 32 rear, 50/34 front, and the shifting is fantastically good. Truly great.
But I have no idea if it is the lightest.
PostPosted: Sun Jan 12, 2014 8:17 pm
Why not put the new Ultegra 6800 one on a diet... assuming your shifters will work.
PostPosted: Sun Jan 12, 2014 9:50 pm
Yeah, I'm not sure if it would work as it is an 11 speed on the 6800.
With regards to taking it to bits, how do you remove the pivot pins? They look like a bit of a pig to get out.
There are no new unread posts for this topic. Rear mech hanger chain rub
tinchy
Thu Jun 30, 2016 5:25 pm
tinchy View the latest post
There are no new unread posts for this topic. Super Record EPS Rear Mech - 11 X 32 Cassette?
peacefulloflove
Sun Feb 21, 2016 6:23 pm
jrobart View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo Chorus Rear Mech Quality
dave.chippie
9
732
Wed Sep 07, 2016 8:07 pm
nd2rc View the latest post
There are no new unread posts for this topic. Dura Ace and Ultegra rear Mech interchangeablity
weastman
Tue May 24, 2016 11:57 am
junchen View the latest post
There are no new unread posts for this topic. Dura Ace 7700 rear mech problems
Penthousepete
Tue Aug 09, 2016 9:21 pm
Asteroid View the latest post
Users browsing this forum: 3Pio, drchull, Lemond75, mrgray, shonanmike, timoh, wedgie, Yahoo [Bot] and 16 guests
