Bar / Stem Combo Thoughts
LoggingMiles
by LoggingMiles
I just ordered a Tarmac SL4 Pro Frameset from my LBS with my team deal. It is the color below. How do you guys think a 3T ARX II Team Stealth (the darker colors) Stem would look with a 3T Ergonova Pro bar (black and white)? Or should I just go with the ARX II Pro stem (black and white) as well?
Frankie - B
Administrator
by Frankie - B
Is this Weight Weenies? Not trying to insult you, but asking on a forum whether your new frame, fork and seatpost combo should need a black stem with a black stripe or black with a white stripe. Because of the language barrier I'm probably coming across way to harsh. That will never be my intention.
Allow me to help you with your choice after me questioning you: Your seatpost has a white stripe on it. Wouldn't it be beautiful if you could repeat that on the bar and stem? you could change the standard bolts to Ti after you bought it to make it lighter. On the other hand: The black on black components would be nice as the bar is made out of CF. which is way lighter then the AL bar of the pro line.
