Zipp wheels with Enve Pads
civdic
by civdic
Has anyone used enve pads with zipp wheels? My zipp pads are done and I have a new set of enve pads that could be used. Should I give them a try?
Twinning
by Twinning
If it doesn't void the warranty then give it a go
Reason: Deleted the quote.
civdic
by civdic
I'm just curious if the zipp pads and enve pads are made by the same company or perform the same way. They look, feel smell and taste similar. The colour is slightly different. I know swissstop makes the Zipps but I can't seem to find who makes the enve's.
carbonLORD
by carbonLORD
I own both 2013 404's, 6.7 etc and I say don't do it. The ENVE pad compound is twice as hard as the Zipp Platinum Pro (Swisstop) compound and seems like it would be too rough on the Zipp rim finish.
Just pony up $40 bucks and get the Black Prince, I think they are allowed by Zipp, (I know they are for ENVE now) but dont quote me there.
Zipp has live chat, why not ask them?
http://www.zipp.com/about/contact.php
carbonLORD.com
eric
by eric
What do they taste like? Have you done a blind tasting with other carbon pads? Or perhaps a vertical tasting of different vintages of Zipp pads?
Wine geek jokes aside I agree, ask Zipp.
sawyer
by sawyer
I have used ENVE pads on zipps ... but yes, they are harder than Zipp pads which are very soft, and Zipp advise people to use softer compounds.
Fine if you're not in the mountains but otherwise there are better options. Reynolds blue are a bit softer also.
civdic
by civdic
Alright...zipp it is. Anyone looking for Enve pads?
mellowJohnny
by mellowJohnny
Good call...
And the definitive answer is always http://www.zipp.com/support/maintenance/brakepads.php
BTW the Black Prince work very well...wear is fast, but stopping power is quite good. In fact I had a AL DT Swiss back rim and my regular 202 on the front for a while and I got better stopping power from the front wheel vs the rear. Sure, physics plays a role (or is that a "roll") but I was impressed at how well my carbon wheel stopped vs the aluminum.
Tricky1
by Tricky1
I called Zipp a few months ago on the same topic, and the Enve pads were not approved. I tried the black prince pads, and Zipp tangente's (grey compound), both with alarming wear rate, but good performance. Finally settled with Zipp cork pads. As I'm a bigger rider, they wear much, much better and perform adequate. They're about the best all-around pads (no exp. in the wet though) I've found so far.
gitsome
by gitsome
According to the latest testing in Tour Magazine even uttering the words Zipp and Enve in the same sentence may cause spontaneous combustion and a dangerous explosion.
My wallet is the lightest thing on my bike.
Zigmeister
by Zigmeister
Zipp platinum pros are great on zipp wheels.
