It is currently Sat Jan 20, 2018 8:26 pm
Post new topic  Reply to topic  [ 66 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: Felt F1 FRD 2014
PostPosted: Mon Jul 07, 2014 6:59 pm
SuperDave wrote:
Wildman wrote:
So last night I finally got my hands on it... 7kg so not uber light but I'm happy.
Wow, that looks mean.
Just finished off the 2015 version and photoshoot and I can say I might like the look of yours just as much as the new one.
-SD
I imagine the 2015 will take 12 months to arrive ;)
PostPosted: Mon Jul 07, 2014 11:52 pm
Sometime in the 2015 calendar year, yes.
No huge changes from '14 though, a couple tidbits shaved a couple grams.
-SD
Deleted the quotes. Please use the reply button.
http://www.3Tcycling.com
https://www.strava.com/athletes/164090
PostPosted: Tue Jul 08, 2014 7:39 pm
Seeing as it took you guys so long to get the 2014 frames out I'll stick with mine for a bit longer... ;)
PostPosted: Tue Jul 08, 2014 9:43 pm
Yes, :roll: I just couldn't bear to get rid of any of them and stockpiled them in my secret warehouse, once I learned there were no changes for 2015 planned, I trickled them out to the world.
-Dave
Deleted the quote. Please read this: viewtopic.php?f=7&t=126225
PostPosted: Wed Jul 09, 2014 3:44 am
Dave, maybe you have answered this before…but why stick with a bb30 as opposed to pf30?
PostPosted: Thu Jul 10, 2014 1:34 am
Weight, primarily. Personally I do like BB386EVO standard and it seems many crank makers are beginning to offer their BB30 cranks with 86 width compatibility.
As light and stiff as the F platform is you have to remember it was introduced in 2011 which means much of the development was done in 2009 and 2010. A lot has changed since then from a manufacturing standpoint. For example, Trek and Scott have caught up with their 1000g framesets.
We've changed the molding methods and material of the F but not yet the frame mold/shape.
Once we start seeing bikes come close in the STW category, we'll look at a re-write.
-Dave
Deleted the quote, as this is clearly a reply. Please use the reply button in these cases, it makes life so much easier. Please read this: viewtopic.php?f=7&t=126225
PostPosted: Thu Jul 10, 2014 3:22 pm
Thanks! always appreciate your insight!
PostPosted: Fri Aug 01, 2014 5:05 am
Deleted the quote, as this is clearly a reply. Please use the reply button in these cases, it makes life so much easier. Please read this: viewtopic.php?f=7&t=126225[/quote]
It has been drilled into me to always quote the poster to protect myself and provide context. Apologies if this is in conflict with the forum rules.
-Dave
PostPosted: Tue Sep 02, 2014 2:46 pm
Does the F1 FRD work ok w/ Athena EPS? I can find a mini group pretty cheap right now and it's only a tad heavier than Record EPS...
PostPosted: Tue Sep 02, 2014 7:39 pm
Yes, the F1 works with Athena EPS
Yes, the F FRD works with Athena EPS
There is no F1 FRD frame, this misinformation has continued to be delivered on this forum but if you review our website the differences between the two frames are detailed.
The F FRD only works with electronic shifting systems or single ring mechanically shifted groups (CX1, etc.)
The F1 frame allows any type of shifting/component group mech/hydro/electronic to be used.
The F FRD frameset is ~1000g
The F1 frameset is ~1200g
-SD
PostPosted: Tue Sep 02, 2014 7:45 pm
SD the semantics police ;-)
Thx for the info, I knew FRD was electronic only, just wanted to make sure it worked with Athena as since it's being discontinued, can be found for reasonable.
PostPosted: Tue Sep 02, 2014 7:54 pm
-SD
Is that F1 weight for the new 2015s with Textreme? Does that weight include frame and fork only?
PostPosted: Tue Sep 02, 2014 10:53 pm
-SD
Yes, that's the new F1 with UHC Advance + TeXtreme and MMC construction, not the old UHC Ultimate + Nano with DMC construction. We are using the UHC Ultimate + Nano on the F1 PR for 2015 but that's a different frame platform intended to be stiff and crashable, not a STW leader.
-SD
PostPosted: Wed Sep 03, 2014 10:18 am
Since we're on the F1 PR, haven't seen a geo chart for it yet?
PostPosted: Wed Sep 03, 2014 5:59 pm
It is on our website:
http://www.feltbicycles.com/USA/2015/Bi ... F1-PR.aspx
-SD
There are no new unread posts for this topic. Felt
Thenuge
14
1614
Fri Aug 11, 2017 5:33 pm
Renne View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
There are no new unread posts for this topic. 2014 Addict Team Edition HMX
jzinckgra
9
717
Sun Nov 19, 2017 1:23 am
jzinckgra View the latest post
Users browsing this forum: Attermann, Bing [Bot], dalex, Google [Bot], Google Adsense [Bot], MayhemSWE, stormur and 46 guests
cron
