Rotor Flow vs Rotor 3D+ 2014
Going to do either or with the MAS Spider and Aero rings. The new 3d+ (2014 version) is about 100g lighter than the Flow from what I can read but the Flow has an aero advantage and was designed with the help of the aero guru at Garmin-Sharp.
What would be better for a Cervelo S5 which is largely ridden on the flat? Bike is already quite aero with 52mm Cosmic Carbone wheels.
Cheers in advance.
Cheers in advance.
i can't comment on the flow ,but i had a new 2014 3D+ with aero q-rings and i had nothing but issues with it flexing so much. I do hope it was just mine ,but i returned it and exchanged for a DA9000 and all is good
. It could have been a bad first batch or just a one off or even nothing wrong with it,just the shimano's being stiffer.
It's probably the rings and not the cranks that are flexy.
I would go with the 3d plus and save the cash.
Can't agree that Rotor crank or aero rings are flexy. I run the Rotor combo with the same tight clearance as I did with DA7900 and I have no rubbing against FD.
I think the gain from the Flow crank is really marginal if you're running the aero rings.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
Scott Scale 35 26"
i had massive flex both sides of the FD when power put down the aero rings flexed alot without much effort in my hands as well ....the DA doesn't seem to move ,so the DA is staying ....
contacted rotor and they said they would contact spain ,but they didn't really want to know if i'm honest with you i'm expecting rotor to get back to me .
IchDien wrote:Cheers guys. Anyone else with thoughts?
If it's for an S5 that will mainly stay on the flats then you should definitely go for the Flow, since this is much more in keeping with the rest of the bike's purpose. Last year I even went for the Flow on my R5 that is mostly used in the mountains, mainly because of better aesthetics and little weight penalty for the improved aero.
Got any pics of it. I have an S5 too and I'd love to see how yours turned out. I've been contemplating the exact same question.
- Similar Topics
- Replies
- Views
- Last post
- 8 Replies
- 473 Views
Last post by lewolive
Wed Apr 11, 2018 9:13 am
- 52 Replies
- 3452 Views
Last post by uraz
Mon Nov 13, 2017 2:48 pm
- 1 Replies
- 401 Views
Last post by dfischer1
Sun Oct 29, 2017 2:50 pm
- 4 Replies
- 827 Views
Last post by TobinHatesYou
Fri Jul 28, 2017 6:13 am
- 3 Replies
- 568 Views
Last post by NickKanwetz
Tue Jun 13, 2017 4:32 pm
