It is currently Sun Apr 30, 2017 5:56 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Jan 02, 2014 2:00 am
I am looking for a 130, 140 mm stem that is reasonably stiff, reasonably lightweight and is approx level with the ground. I believe that would be approx 10'? I have come accros the Shimano Vibe but am looking for other options.
PostPosted: Thu Jan 02, 2014 2:20 am
The Thompson x2 is probably the coolest 10 degree stem.
PostPosted: Thu Jan 02, 2014 2:33 am
A -17' be "level with the ground"......assuming a ~73 degree headtube angle.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Jan 02, 2014 10:25 am
Yeah, looking at the front fork angles of current bike frames a -17 angle stem will be the closest to a parallel with the ground set up.
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Thu Jan 02, 2014 11:02 am
Easton EC90 SL is 10deg up to 130mm. Website weight is 110g (100mm), matte carbon finish.
http://www.eastoncycling.com/en-ca/ec90-sl-1218
or the aluminium EA90 10deg up to 130mm. Website weight is 130g (120mm). black anodised finish
But if it is a horizontal stem you are after look for a -17deg such as the 3T ARX Team, now come in up to 150mm too.
My 140mm -17deg ARX (now have ARX II with torx bolts) weighs 148g.
PostPosted: Thu Jan 02, 2014 11:11 pm
Deda zero1 come up to 130mm and the superleggero and the Zero 100 are upt o 140mm long. I like deda stems.
www.thecycleclinic.co.uk
There are no new unread posts for this topic. I'm looking for Aeroad build suggestions
lovemyway
9
758
Thu Aug 04, 2016 6:14 pm
thumper88 View the latest post
There are no new unread posts for this topic. Birthday build.... looking for suggestions
jever98
7
484
Mon Mar 06, 2017 10:35 am
jlok View the latest post
There are no new unread posts for this topic. bike fitting and suggestions help
bigpab
Sun Jan 22, 2017 11:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Lightweight Trackframeset suggestions
JLS
34
1525
Wed Jan 25, 2017 5:19 am
There are no new unread posts for this topic. Need suggestions for disc rear hub please & options not found
MichaelB
Fri Aug 05, 2016 5:06 pm
savechief View the latest post
Users browsing this forum: Bing [Bot], chazmtb, ghisallo2003, krusty, stormp, trimenc, Yahoo [Bot] and 41 guests
