where can I find a higher headset cover
by Dennis
I'm looking for a higher headset cover for my Ritchey headset. I would prefer in UD carbon.
I noticed that some headsets are sold with a dustcap of around 15 mm. Mine is around 6mm.
This way I could loose the regular spacer under the stem and would look better.
So, where can I find this? I don't think Ritchey sell these separate.
by DMF
PRO (Shimano) makes a nice tapered one in UD, also try Cane Creek as they have UD-versions. The PRO one is clean from all and any logos which the CC one is not.
by Stolichnaya
I believe you can get a tall cap from FSA as a separate item as well. You might need a thin spacer to get the right compression underneath but with a little cobbling you'll find a solution.
