Open Pave CG hop?
Valy
by Valy
Hi guys, just bought a 2nd Open Pave CG to go on the rear and noticed a hop in the tire after installing it. Resat, inflated to 130/140psi - still a hop. Tried on a different wheel that had the older (same model) Pave CG on it without hop, the new on ended up having the hop on that wheel @ same pressures, properly seated etc.
The hop is a max of 1-1.5mm but the older tyre barely has any hop on the same wheel. FWIW the newer tyre came in old packaging (of the previous model) with a printed label stuck on to signify the newer model.
Anyone come across this?
A bit less pronounced than reality
http://www.youtube.com/watch?v=6RiUZZOZ ... e=youtu.be
TwiggyTN
by TwiggyTN
Sometimes, but it's rarely something I'd feel on the road. I'm 95% on tubulars and the nicer hand made ones can have a lot of variation in the casing but it's no big deal unless it's very bad. I'd ride it but if it bothers you just return it for another one before you ride on it.
Sent from my Galaxy Nexus using Tapatalk
em3
by em3
...no offense, but you are kidding, right? Your video shows some sidewall inconsistency, but that is certainly no measure of a vertical hop in the tire. You need to assess a hop from the top/tread side of the tire. Also, a 1-1.5mm hop on a 24-25mm tubular at proper pressure will certainly not be felt on the road.
Ride them and enjoy the magic carpet ride of paves.
EM3
______________
legs 11
by legs 11
Nothing wrong with that mate.....pretty standard.
The tyre doesn't appear to have any hop in it on the outside edge, it's just little wobbly on the line where the colours meet.
Pedalling Law Student.
Valy
by Valy
If you judge the caliper you see the variation. I don't care about the sidewall being out of line. Don't think I've had this before with any tire including 2 cx EVO ii hence wondering
Fiery
by Fiery
Looking at the top surface of the tire - I've had more outer diameter inconsistencies than that with clincher tires. You won't feel it on the road.
spdntrxi
by spdntrxi
I agree with others.. you won't feel that on the road.
bm0p700f
by bm0p700f
I have a bit of hop on mine, they still feel very comfortable.
Valy
by Valy
You are right guys, it's just that I can sadly get very, very fussy with things and it's more that thought of it than reality.
I have a rear wheel with probably the same amount of hop as the tire, but it does not bother me as I know it can be adjusted but with a tire I know that it's how it will always be. :/ Pretty sad but that's how I can fixate on things sometimes.
Thanks for the replies!
btompkins0112
by btompkins0112
It will only be like that until it wears out. Just ride it a lot and it won't be like that for long!!
