Solid cable housings?
myndog
by myndog
Hi, i'm about to change my aliuminium frame to carbon one. The new frame has integrated cables. Could someone suggest a solid cable/housings kit? Housings should include shifting cable adjuster. I'm thinking of Jagwire. What is your suggestions? Thanks. :wink:
nicrump
by nicrump
OEM for the shift system you use.
Reason: deleted the quote, as this is clearly a reply.
vdrey
by vdrey
Segmented cables if you want high end. If you just want something that works, any name brand or OEM would work.
Sent from my Nexus 7 using Tapatalk
voodoojar
by voodoojar
I don't know the exact frame you have but the way I do it is run I-links with a custom frame stop then run just the liner internally to save weight.
myndog
by myndog
I got Mathot prospect frame. If you never heard about them you can google it as its not very known company. Yes VDREY i looking for some high end cables that won't cause me any problems as i'm preparing for the next season :P
Krackor
by Krackor
myndog, any update on your cable housing choice? Did you pick the new Jagwire Elite Link system? I'm looking for feedback on the Jagwire but search seems to be turning up nothing. :noidea:
