It is currently Fri Jan 19, 2018 4:42 pm
 Post subject: Nashbar Steel Fork
PostPosted: Sun Dec 15, 2013 4:24 pm
I'm building a rugged crit/do-everything bike. I really intend to disrespect this bike, curbs, gravel roads, grass shortcuts, skateparks, etc. Plan is a Nashbar aluminum frame... But what fork? I want a Steel Nashbar fork (40º rake) because they look awesome. Would you trust it? What else would you recommend?
_____________________________
I'm handsome
 Post subject: Re: Nashbar Steel Fork
PostPosted: Sun Dec 15, 2013 7:02 pm
I've seen forks fail in every material, but strangely enough more often in steel than others. Not sure why, perhaps fatigue? They've always failed at the steerer just above crown, leaving the person hospital-bound.
Anyway, carbon will be fine for what you want to do with it. Personally I'd go with a full carbon fork.
http://www.youtube.com/watch?v=CNKe0idF7EM
PostPosted: Mon Dec 16, 2013 2:31 am
I commute on the Nashbar (grey) aluminum frame, I used the Nashbar Steel Road Fork for a bit, but the low rake gave the bike a super twitchy feel, so much so, that it was very difficult to ride without my hands on the bars. After a little crash (don't text and ride, kids), I put an old carbon fork with 45mm rake on the bike, now it behaves much more manageably. Of course, the short top tube means it still has mad toe overlap (on a 58 btw), but it is rather pleasant to ride now.
Also, I have completely abused this bike for the past year, it gets left out in the rain, freezing temperatures, rode down small flights of stairs, and hopped off curbs. It is a tough frame.
PostPosted: Mon Dec 16, 2013 4:24 am
I have not broken a steel fork (the one I had briefly before replacing it with carbon). But I have also not broken a carbon fork, even when impacting an off-road terrain that broke my ti frame at the headtube. That particular one was alloy steerer, but I agree with prendrefeu that full carbon sounds just fine.
PostPosted: Mon Dec 16, 2013 9:43 am
I broke a carbon steerer (really thick one at that too) when a car hit my handlebars at excessive speed (got T-boned), the steerer got twisted apart right above the alu reinforcement at the crown. The alu frame was just fine...
I think it's, as usual, pointless to make generalisations among materials. It's a matter of construction, not material.
The Shivenge
PostPosted: Mon Dec 16, 2013 11:28 am
Thanks for the replies. I'd still like more information if anyone has something to add. DFM makes a good point:
I'm also confident a carbon fork will meet my needs, but it's not what I want. I want the straight blade Nashbar steel fork because it is going to compliment the rest of the build.
I'm handsome
PostPosted: Mon Dec 16, 2013 4:49 pm
DMF's point was echoed in the earlier comment of "forks fail in every material" ;)
But, anyway, get whatever works for you. There are straight-blade carbon forks around as well, and this is weight weenies. A lighter fork does make things feel a bit more nimble in the steering department.
PostPosted: Wed Dec 18, 2013 2:10 pm
Did the same thing for the same reason on my Serotta titanium cx bike. Check it out here http://www.flickr.com/photos/quality_vintage_bikes/sets/72157636789945366/. I ended up buying a Traitor Cycles steel fork though.
A proper steel fork will handle pretty much everything you can throw at it. The same goes for most (modern) carbon stuff, but obviously these don't handle crashing a bike nearly as good as a steel fork does. That said, you should note that a steel fork is much heavier (approx. 700g) than a carbon fork and it is not nearly as stiff compared to a carbon fork. The latter will definitely result in brake shudder and lesser cornering ability of your bike.
Good luck with the build! :thumbup:
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
There are no new unread posts for this topic. Steel, Stainless steel or Titanium ?
stormur
18
2069
Sun Dec 31, 2017 10:07 am
stormur View the latest post
There are no new unread posts for this topic. Fork length Ridley Helium SLX fork?
Beaver
Mon Jul 17, 2017 5:31 pm
Beaver View the latest post
There are no new unread posts for this topic. Colnago steel - From 10s to 11s .. what to watch out for ?
Kupepe
Wed Mar 29, 2017 8:24 pm
shimmeD View the latest post
There are no new unread posts for this topic. 1980~ Steel classic.
Littlemad
Tue Nov 21, 2017 11:50 am
Littlemad View the latest post
There are no new unread posts for this topic. Steel OR Carbon / Calipers or Disc
stevenak
16
1413
Mon May 22, 2017 11:46 am
Fixie82 View the latest post
Users browsing this forum: FredV, keaton, tnkn and 49 guests
cron
