It is currently Mon Jan 22, 2018 3:15 am
PostPosted: Sun Dec 15, 2013 8:37 am
Please help with new frame choice.
I already have Colnago EPS 61 traditional geometry during last 2 season.
It's a super bike, but with my 6'2'', is awfully not aero)))
Compare to my previous GIANT TCR Advanced ISP , old , 2007 year model.
Colnago about 1 km/h is slower at same power, course etc.
I don't want to use two bikes for trips on races since it is expensive in transportation in the avia plane.
I sold my Cervelo P3C, it is clear that it isn't comparable with a usual road bike, but Colnago with clip-on aerobar is awfully slow. It with comfort, but is senseless to participation in a TT races. As far as Scott Foil will meet my expectations, it is also possible it it will be slightly easier than Colnago (1250+360 gramm at 61s size).
I hope to hear of real responses of owners of Scott Foil, I consider 58 size.
Or I should continuing to enjoy Colnago, possibly it is my conjectures.
Cervelo was awful for bad pavings road, I couldn't give out on it the maximum power. It was uncomfortable and very rigid, ideal for glass road (not around).
I considered S5, but it is the same pain as it seems to me. If Scott same "a piece of plywood", it not option for me
Sorry for my poor english
Regards.
PostPosted: Sun Dec 15, 2013 7:06 pm
Hi! It sounds to me like your two main criteria are comfort and aerodynamics. I have test ridden a scott foil, and while I have no basis to judge it's aerodynamics, it didn't feel any faster than my aluminum bike, but was definitely a lot more harsh (and I ride gatorskins at 120 psi most of the time, so it wasn't wheels/ tires).
I haven't ridden the S5, but from what I hear, it won't be as stiff bit definitely is one of the most comfortable aero road bikes. If it was me though, unless you're set on doing TT's in long distance travel races, I would just stick with the colnago. It sounds like a gorgeous bike, and it would be a shame to have to sell it. Whatever you chose, good luck at the races!
PostPosted: Sun Dec 15, 2013 10:20 pm
I had a foil 61cm...and I sold it pretty quickly. It was hard, stiff and harsh.
I miss have a Trek madone 7.9. Great bike. Much more comfortable, and handles differently to the foil. Possibly not as well on the front end, but that would be hard to prove.
I can't comment on the cervelo. All tunnel tests suggest that it is more aero than the Scott or the Trek.
Also, consider the 58 rather than the 61 of you can make it work fit-wise.
Sent from my Nexus 5 using Tapatalk
PostPosted: Mon Dec 16, 2013 4:37 am
Ok, thanks for responses. I will continue to racing on Colnago EPS. 61S a little big for me.
PostPosted: Mon Dec 16, 2013 6:02 am
Whew! By the way, from the pic it doesn't really look like your bike is too big but that's totally your call. Not sure why someone would suggest you get a 58 unless they had way more information about you than could be found in this thread, before the pic even. And when referring to its size it should be referred to as a 61, or 61 traditional. At first I thought your added "s" behind the 61 was just a typo but you did it again. The "s" indicates sloping which yours is clearly not and the largest sloping size they make is 58s. Maybe it was just two typos because you clearly know the difference.
Colnago C60 - PR99; Trek Koppenberg - Where Emonda and Domane Meet;
C59 Five Years Later
Trek Emonda SL Campagnolo SR; Special Colnago EPQ
PostPosted: Mon Dec 16, 2013 11:20 am
Looks pretty sweet to me Camber. :)
Personally, I would never even consider the change you proposed. :beerchug:
Pedalling Law Student.
PostPosted: Mon Dec 16, 2013 1:22 pm
My 6532gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Tue Dec 17, 2013 8:32 am
Yes, it's my mistake,
61 size (not sloping) have 590 mm ETT. The original Colnago seatpost will be replaced to 3T Ltd with zero feedback. It will allow to install saddle optimum ~ 80-90 mm of seatback from BB. It 's large size frameset problem, with 73 degrees of a saddle tube. The saddle appears too behind. I'm look to something is shorter with ETT 580. To buy new Colnago ... it it is expensive. It is strange that they aren't really appreciated in the secondhand market. Maybe because Colnago use oldschool lugged technology. All people look to new modern aero sexy frameset. I continue to use in the winter the youthful steel GIOS TORINO (I am 42 years old), and it isn't much worse present top carbon.
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6903
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott Foil HMF Build
ab01ns
Sat Dec 16, 2017 5:30 pm
banik69 View the latest post
There are no new unread posts for this topic. Scott foil frame finish
toastie
Mon Apr 03, 2017 6:18 pm
toastie View the latest post
There are no new unread posts for this topic. Bottom bracket scott foil
kelih
Wed Jul 12, 2017 1:44 am
MAsshole View the latest post
There are no new unread posts for this topic. Scott Foil - Syncros RR1.0 Handlebars
p3dalfaster
7
1474
Wed Aug 16, 2017 7:27 pm
Indyx View the latest post
Users browsing this forum: BikeAnon, Catagory6, dbnm and 35 guests
