Giant Tcr Advanced SL - running 25mm tyres
upside
by upside
I have a new TCR Advanced SL coming soon and would like to install 25 Conti's on the rear. Is this going to work or is the 25 going to be tight. Thanks for your help :beerchug:
Stoo
by Stoo
Fine.
I've run 25's on my 2012 model just fine.
'18 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'18 Giant TCR Advanced Pro 1 - R8000 - QuarQ DZero - SLR1
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'13 Giant Trinity Composite - U6800 - QuarQ DZero
Horacio
by Horacio
2013 TCR Advanced SL1 with Vittoria 25's...tons of room!
upside
by upside
Are 28's possible. I picked up a set of Schwalbe Ones intended for a Classics Domane, but since have cancelled that bike..so have a set of big tires. My frame will arrive next week, so I can find out what will work. Thanks
Horacio
by Horacio
Never tried 28's but I think they'll work.
jamescarroll
by jamescarroll
I'm on a TCR ADV sl 0 '13 and also have Shimano DA C50 wheelset '13. Shimano recommend 25mm for the C50 and yes it is a tight squeeze getting the back wheel on & off. 25mm will work, but I would suggest 28 wouldn't.
hope that helps
carbon337
by carbon337
A friend had a few issues on a road race in the UK whilst running conti 25s. They were on a '12 tcr adv sl using zipp 303 firecrest clinchers the new wider wheels. He ended up with a small stone down the back of the seat tube and the tyre causing wheel to jam. Could have happened with 23's too I'm sure. Just bad luck I guess. Other that that and us younger folk calling them Granda tyres he seems to like them.
ms6073
by ms6073
Horacio wrote:Never tried 28's but I think they'll work.
I think the answer actually depends on the wheels as 28's on narrower rims will probably work where as Zipp Firecrest 303/404 wheels probably not so much.
Horacio
by Horacio
I'm on DA C24s and like I said, there's a lot of room. I also run Zipp 303FC with Vittoria 25s on this bike without issue.
Stoo
by Stoo
Forgot to mention above, I have run 25's on 303FC's with no issue
