25mm tires on 2008 Cervelo R3 frame?
critracer26
by critracer26
Has anyone tried 25mm tires on a 2008-9 CerveloR3 frameset?
the jackel
by the jackel
They fit on my 2007 R3. I ran Conti Gatorskin hardshell for a little while with no problems
eric
by eric
It'll clear the frame no problem but the fork is tighter (depends which fork you have).
naisan
by naisan
2008 r3 sl I have 25mm veloflex roubaix / arenberg on zipp 303fc and 404fc tubulars. Been running for 5 years. No prob.
Sent from my SCH-I605 using Tapatalk
naisan
by naisan
Btw 3t funda fork n sram red...
critracer26
by critracer26
Thanks guys, its got the Funda fork so I think I will be ok.
FourRings
by FourRings
It will depend on the rim. 25s fit with no problems on my '07 R3 when mounted on a narrow rim. Mounted on a wide rim like a Zipp 303, 25s rub front and rear.
critracer26
by critracer26
they will go on bonty race x lite wheels
Andrewjn
by Andrewjn
I have a set of Michelin pro optima 25's on a set of campy neutrons on my R3 and they fit easily. The fork was a cervelo one from the original R2.5 tho. Ride is very good adding to the already smooth ride of the R3. No noticeable decline in performance and run a slightly lower pressure
WillT
by WillT
Sorry to bring up an older thread - thought it would be better to add to this one instead starting a separate one. Didn't see much mentioned about clincher rim width. Anyone run 25mm tires on 23mm wide rims (C2's, Archetypes, TB14's, etc.) on their older R3 (before the geometry changes)? Looking to possibly pick up an older 2007 R3, but all I run are Vittoria and Veloflex 25mm clinchers on wide rims.
