It is currently Tue Jan 16, 2018 12:46 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Dec 09, 2013 12:08 pm
Anyone else running RotoR crankset with Q-rings on a Litespeed Archon T1 :?: :?: :?:
or any frame to think about it that doesn't have a braze-on mech
Running gear on my archonT1 with rotor 3D+ BB30mm with 36/52 Q-rings and shimano Ultegra 2014 11 speed ..
I have front mech issue's and wondered if anyone else had the same problems...
I've been told it's to do with my seat tube geometry and with it being a clamp-on as well front mech.
(badly rubbing chain from gear 5-11 bottom ring and 19-22 not so bad on the top ring)
:thumbup:
PostPosted: Mon Dec 09, 2013 10:51 pm
Can you post some photos, so we can see the problem
PostPosted: Mon Dec 09, 2013 11:22 pm
i'll take some tomorrow and post them :thumbup:
i cannot seem to find how to upload photo's :noidea:
i could on the intro page ,but that had an upload area under this posting editor .... :oops:
PostPosted: Tue Dec 10, 2013 2:25 pm
photo bucket or flickr, then copy and paste the img link
PostPosted: Tue Dec 10, 2013 2:39 pm
photo bucket or flickr, then copy and paste the img link[/quote]
Ok thankyou :-)
deleted the quote.
PostPosted: Tue Dec 10, 2013 4:45 pm
It wouldnt be more likely because your mech is trying to deal with the ovalized ring would it?
Spend a bit of time getting the height right and tweak a little here and there.
I cant see that braze or band on would make much difference.
I run an large osys ring on my tt bike but a round inner and setting up can be a little testing, but once its there, you should be okay :-)
Official cafe stop tester
PostPosted: Tue Dec 10, 2013 9:13 pm
I uploaded a few photo's to flickr to show the issue i'm having ....
I contacted rotor and it seems that the geometry of my seat tube frame is slightly more of an angle and with the Ti frame only having a clamp on front mech means it cannot be adjusted.Rotor do a mech kit to help with this and with a clamp kit as well and replace the front mech with a braze on should give me the adjustment to rectify the issue .
i'll keep you posted and put some more photo's on flickr when it's been done ... :wink:
http://www.flickr.com/photos/111174426@N07/
PostPosted: Wed Dec 11, 2013 12:08 am
Looks like you need to change the angle of the FD which would let you lower it, have you tried spacers where the derailleur and seat post clamp connect to push the FD backwards (braze on front derailleur with a clamp) , which will then allow you to lower it some more.
I think this is what the rotor kit is doing.
If you have a clamp on one piece derailleur this is going to be hard to do, is the clamp separate to the derailleur or is it one piece ?
PostPosted: Wed Dec 11, 2013 8:58 am
good call Iannes ....thinking the same same thing ,so dropped rotor a call and they do a F Mech Kit with 2 spacers 2mm & 6mm which will rectify this problem ,but i need to change from clamp to braze-on derailleur which means adapter the kit and replace the front derailleur and hope it can all be adjusted up ....
i will when i get the parts sort out some photo's to see the difference :D
PostPosted: Fri Dec 13, 2013 7:09 pm
Just a little update .....spent 4 hrs in the bike shop with the 2 technicians and with installing the rotor fix with a new braze on mech ,as well as an ultegra clamp band .... we did sort out the gearing to the point of being able to use 20 of the 22 without any rub from chain ,but this was expected .
The crankset was also taken out checked and re-installed to try and get shot of the crank creek i thought i had ....
On test ride the creek was there when pushing on the crank in or out the saddle .
Adjustments went on and wasn't looking good ..
Last chance was to put clamp on mech back on and just install a basic shimano chainset and see what happens ......you guessed it all 22 gears useable and no rubbing or creeking .....
What next ....?????
The rotor 3d+ (2014) we found was flexing to much and also the aero rings, ,s owhen power put down it flex'd to much and rubbed on the mech...
We took all this off and left with ultegra on it at moment in the shop ,but it doesn't look right that chainset and shop agree's
Shop option was to put dura ace 9000 and they have offered me to change the groupo on it to full dura ace and a little cost ....
the shop guys have been great and when sh'e back i'll update with photo's ....
ps ... "not impressed with the expensive rotor ,as the shop wasn't either " :evil:
PostPosted: Fri Dec 13, 2013 11:26 pm
I just changed to the DA 9000 groupset on the Ghisallo, it's great, the crankset is super stiff and just works.
If your not worried about weight, you should go with the Di2 and take advantage of the auto trimming FD, I think then you could use the rotor 3 cranks with no problems
http://www.youtube.com/watch?v=q0MDurGkreI
Are you sure the FD rub is not from the lack of bottom bracket stiffness rather than the crankset and chainrings ?
PostPosted: Sat Dec 14, 2013 5:00 pm
I'm not saying the litespeed archon t1 is the stiffest ,but its no banana by any means ...
Wasn't to keen on having external di2 cables running over the bike as it has only external cabling ....
The shimano is just showing how stuff it really is compared to a like for like rotor and with a BB30mm ....
PostPosted: Mon Dec 23, 2013 9:18 pm
Got the girl back ......rotor all gone and due to having crank change out the ulterga didn't look right on the bike ,so the bike shop wasn't happy with the look and stripped it down and put 11 speed dura ace on her ...she's back looking sweet,sharp and very attractive ...can't wait to get some miles on her now after i had a little test ride ....hope to sort out some photo's ...
:thumbup:
PostPosted: Fri Dec 27, 2013 11:00 am
First run out with everything working and running smooth as silk , just waiting for a narrow saddle to turn up to swop it over ..... :arrow: :arrow:
There are no new unread posts for this topic. etap rear mech issue
carbon337
Mon Jul 17, 2017 3:51 pm
Adamchinnyb View the latest post
There are no new unread posts for this topic. Ultegra Di2-Chorus FPS, Mech Record
digitalnorbs
Sun Oct 22, 2017 6:19 pm
digitalnorbs View the latest post
There are no new unread posts for this topic. Ultegra 6800 to Rotor 3DF 30mm on Giant TCR advanced 2 (2010)
chinoph
10
816
Tue Jun 13, 2017 8:14 pm
benp View the latest post
There are no new unread posts for this topic. Chorus 11-speed front der. shifting issue
Catagory6
Tue Oct 24, 2017 12:21 am
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2930
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
Users browsing this forum: Bing [Bot], Conza, fh8425, Google Adsense [Bot], Marin, Voye and 45 guests
cron
