It is currently Thu Nov 23, 2017 12:31 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Dec 02, 2013 2:59 am
Is this analysis of mine correct?
Original Campagnolo 10 speed cassette sprockets were not positioned evenly. Sprocket pitch varied, and this was because original 10 speed Ergolevers pulled differing amounts of cable depending upon which shift you were doing on the ratchet ring. On the other hand, the sprockets on newer 10 speed cassettes are spaced evenly, and no matter what shift you do with the Ergolever it moves the RD the same amount each time.
My point being .... newer, evenly spaced cassettes will not work properly with original 10 speed Ergolevers.
Thanks.
PostPosted: Mon Dec 02, 2013 3:04 am
Nonsense.
Putting it another way - just wrong.
Where does this crap, sorry - mistaken idea, come from?
It's been the same for the last 13 years - ever since 10-speed was born.
There's sometimes a buggy.
One.
PostPosted: Mon Dec 02, 2013 9:45 am
Agreed, this is all incorrect.
I actually had a Miche cassette that was evenly spaced and "campag compatible". It shifted like rubbish and was impossible to set up. This was using the last Athena 10sp.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Mon Dec 02, 2013 12:34 pm
So, just to repeat. Campy's 10-speed sprocket spacing is the same today as it was in 2001.
Because of the different number of paired sprockets used on the various levels, different spacer thicknesses are used, in order to maintain an even sprocket spacing. Because with paired sprockets the spiders can be a little recessed.
Spacers are 2.4mm between flat sprockets excepting the 6-7 sprockets which have a 2.55mm spacer. Again, this is a long-standing practice.
On all loose cog cassettes, the first spacer by the large sprocket is thinner because the sprocket is dished towards the wheel. Final spacing is the same.
One.
PostPosted: Mon Dec 02, 2013 2:24 pm
Shop Owner / Manufacturer
All Campag 10 cassettes are differentially spaced - true.
Has the spacing changed since 2001? - No, they have remained consistent.
Are they all the same - no.
The spacing between the 11 and the 12 on an 11-up is slightly different to the spacing between the 12 & the 13 on a 12-up, which varies very slightly again when compared to the 13 and the 14 on a 13-up.
Since each sprocket in these cases carries it's own spacer, in practical terms these differences are not important.
On 11s cassettes the differential spacing extends over the top 3 sprockets - so the 11-12-13 spacing is different to the 12-13-14 and the 13-14-15.
The reason for differential spacing at all - the precise reverse of what the OP states - cable recovery on click "1" of an ergo lever is slightly greater than on clicks 2-9, but clicks 2-9 are consistent in the amount of cable they recover. The problem is that the angular movement in the chain at the middle of the cassette required to make the shift is less than that at the extremes - so alongside the geometry of the RD, the spacing of the sprockets works to allow a unitary recovery of cable to give a clean shift on each sprocket.
Shimano and SRAM do it a different way.
In 9s it's not such a big issue and in 8s, not an issue worth worrying about at all.
HTH
Graeme
Velotech Cycling Ltd
Campagnolo Main UK Service Centre
PostPosted: Mon Dec 02, 2013 2:44 pm
Graeme obviously has more detailed knowledge than I do. Mine is just based on years of using and playing with a variety of 10-speed cassettes. Plus regular visits to Campy's site.
As for OP's main question, I'm glad to see we are in agreement on this.
One.
PostPosted: Mon Dec 02, 2013 9:53 pm
I just couldn't get an aftermarket cassette (Interlock Racing Design) to work with my original 10 speed kit from year 2000. Still trying to work out why it performed so badly. I've now sold it.
There are no new unread posts for this topic. Campagnolo 10 / 11 speed Compatability
Tricky1
Mon Sep 25, 2017 1:36 pm
adson View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
12
855
Mon Aug 28, 2017 12:26 am
c50jim View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed cassette lockring help
Sweetbabyj45
19
1074
Tue Jul 18, 2017 4:54 pm
Sweetbabyj45 View the latest post
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
There are no new unread posts for this topic. Campagnolo Athena 11 Speed Triple LH Lever as a Double?
Mon Mar 13, 2017 4:13 pm
5 8 5 View the latest post
Users browsing this forum: corky, Google Adsense [Bot], jerbax18, Monkeyfudger, naylor343, sinda67, Yahoo [Bot], zappafile123 and 26 guests
