It is currently Wed Jan 24, 2018 10:54 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Mon Dec 02, 2013 1:40 am
I've been thinking about replacing my Cannondale Hollowgram SiSL2 crankset with something carbon. After 10K miles, the chainrings need replacing and I'm dumping the SRAM PF30 bottom bracket for a Chris King to try and get rid of any creaking. My Supersix Evo has Di2 and was debating largely between the new FSA SLK Light and a SRAM Exogram. Am I nuts and should just replace the chainrings? BTW, I know there will be many folks happy to take the Hollowgrams off my hands...;)
Thanks for the help!
-Pete
PostPosted: Mon Dec 02, 2013 1:43 am
Yes you are nuts. Get some new praxis rings.
PostPosted: Mon Dec 02, 2013 2:03 am
You are nuts
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon Dec 02, 2013 2:30 am
Hollowgram for FSA? Seek medical attention ASAP.
PostPosted: Mon Dec 02, 2013 2:36 am
I just checked the calendar and I can confirm that it is NOT April Fools Day.....
Mosaic RS-1
PostPosted: Mon Dec 02, 2013 2:57 am
I have the Chris King on mine and no creaking... Keep the Hollowgram and buy a set of rings. What size do you need? and do you need both of them after 10K
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Mon Dec 02, 2013 3:01 am
Thanks for the replies! I really wanted to keep my Hollowgrams...I guess I just needed validation...:) If I had a full SRAM groupset, I might go Exogram, but I'll probably just get some Praxis chainrings. Glad folks have had luck with the CK bottom bracket. I have them on my MTB and CX bike.
PostPosted: Mon Dec 02, 2013 1:29 pm
I'm not sure what it would look like but you could get the SRAM exogram chain rings (non-hidden bolt). They are priced decently and they shift awesome.
Strava
Bicycle1
Bicycle2
PostPosted: Mon Dec 02, 2013 4:57 pm
So you want to "upgrade" to a less stiff crank the weighs more? Get some new chainrings. I love my SISL2 cranks.
PostPosted: Mon Dec 02, 2013 5:27 pm
Anything you use to replace Si's would have to be pretty spectacular. FSA chainsets........somewhat less than spectacular (not terribly bad, but not in the same bracket as the Si's) ;)
Pedalling Law Student.
PostPosted: Mon Dec 02, 2013 6:36 pm
Oh God! I just purchased a DA9000 chainset to replace my SISL. Going to pair it was the Praxis works BB30 adaptor.
PostPosted: Tue Dec 03, 2013 12:32 am
Sorry dude, you must be mad. What a monumental waste of money.....lol.
PostPosted: Tue Dec 03, 2013 3:46 am
Your crazy! Do not down grade your crank. I echo the Praxis rings.
PostPosted: Tue Dec 03, 2013 5:32 am
If you run shimano the new 9000 crank is miles ahead of any hollowgram crank. And for what its worth hollowgram sisl 2's are only about 20g lighter then SLK cranks. The exogram crank is also nice, but would only suggest running it with a full red group.
PostPosted: Sun Feb 02, 2014 4:24 am
I ended up going with the Chris King BB and Praxis rings. That seems to have solved the problem!
There are no new unread posts for this topic. Cannondale Hollowgram SI SL 1&2 cranksets
alcatraz
Tue Jan 23, 2018 7:43 am
alcatraz View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram in BB386
wheelzqc
Thu Aug 03, 2017 4:30 am
wheelzqc View the latest post
There are no new unread posts for this topic. Worth upgrading to cannondale hollowgram si ?
jobvisser
Thu Feb 16, 2017 10:44 pm
evan326 View the latest post
There are no new unread posts for this topic. New build ideas
ohyeah22
Sun Aug 06, 2017 7:28 pm
ohyeah22 View the latest post
There are no new unread posts for this topic. Various fit issues; any ideas?
TheDarkInstall
Sat May 27, 2017 2:46 pm
TheDarkInstall View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], jacobeh, LionelB, reedplayer and 26 guests
