It is currently Wed Jan 24, 2018 3:11 am
Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Dec 05, 2013 4:42 pm
Any ideas on next steps since it is not normal? I will take some pictures tonight of the wear.
PostPosted: Thu Dec 05, 2013 5:08 pm
Are you absolutely sure that your FD mount is rock solid? Some frames have mounts secured by screws. Others have rivets that may loosen.
My RCA
PostPosted: Thu Dec 05, 2013 5:13 pm
Positive. It is the rivet type, but it is not loose. Completely removed everything from the bike before posting that last set of pictures to check for any play in the braze-on. Hand checked the torque when re-installing the cranks. Checked the torque on the chainrings. Torqued the FD to spec, used the support bolt.
The metal shavings have the completely baffled. I did not think that was normal, and not really sure what to do about it.
EDIT: I just got your PM, but I do not have enough posts to reply. I do appreciate the offer, but unfortunately we are a thousand miles apart.
PostPosted: Thu Dec 05, 2013 5:24 pm
Just out of interest, what torque did you use for the FD?
My RCA
PostPosted: Thu Dec 05, 2013 5:29 pm
I used 7 Nm. That is what it stated in the dealer manual.
PostPosted: Thu Dec 05, 2013 5:32 pm
:? Ok. Stumped.
My RCA
PostPosted: Thu Dec 05, 2013 5:34 pm
I will take pictures of the metal shavings (if any more remain on the chain) and back side of the chainrings on the crank tonight.
I guess my next move is swapping out the crank for the 6800 crank that my group came with and see if it is any better.
PostPosted: Thu Dec 05, 2013 5:40 pm
Take a straight side on view with fd in both positions ( big and small ring). Also see if you can get a closeup of where FD support bolt contacts.
My RCA
PostPosted: Thu Dec 05, 2013 5:45 pm
Thanks, I will take several shots. I am fairly certain I will not be able to get a view of the support bolt with a camera, but I will try.
PostPosted: Thu Dec 05, 2013 9:08 pm
Here are the images. The first couple show you the metal shavings and the weird wear on the inside of the chainrings.
PostPosted: Thu Dec 05, 2013 9:49 pm
I'm wondering whether the initial not so great adjustment when you first installed, caused the FD cage to get bent and distorted under the shifting force. I think you said it actually got stuck on the upshift. That would put a huge force on the cage. For reference, I've taken a picture of my setup (of course its 9070 so not an exact compare), but in particular, note where the FD cage "hinges" to the actuator. Yours is not straight across, looks a bit distorted. Mine is straight across.
PostPosted: Thu Dec 05, 2013 10:02 pm
Also note that my FD height is much lower than yours. I think yours is too high. No more than a dime thickness is the gap to the biggest tooth.
PostPosted: Thu Dec 05, 2013 10:13 pm
Actually, looking at it a bit more carefully, my tooth to derailleur gap is constant over the length of the derailleur, your gap increases along the length of the derailleur cage. So it starts out at the right gap at the front of the FD, then gets bigger and bigger towards the back of the cage.
PostPosted: Thu Dec 05, 2013 10:19 pm
I am going to go to a shop to see if the front of my derailleur is normal. In the meantime is the wear on the back of my chainrings normal? Or does that look odd to you? That is definitely where the shavings are coming from.
PostPosted: Thu Dec 05, 2013 10:30 pm
I've got 2500 km on my drivetrain, and there are no such marks on the inside of my Praxis rings.
There are no new unread posts for this topic. Chorus 11-speed front der. shifting issue
Catagory6
Tue Oct 24, 2017 12:21 am
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Front shifting with close ratio cassette
vinuneuro
Fri Aug 25, 2017 2:57 am
2lo8 View the latest post
There are no new unread posts for this topic. Sram Etap shifting noise/problems shifting smoothness.
Allen254
10
942
Sat Jan 20, 2018 8:27 am
alcatraz View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
774
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
Users browsing this forum: Bing [Bot], Bordcla, Dbfire, dualathlonpc and 25 guests
