It is currently Thu Jan 18, 2018 3:18 am
Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sun Dec 01, 2013 7:39 pm
Online
Height looks ok, I doubt thats the issue. Like I said, your symptoms sound like lack of parallelism and weak FD support.
My RCA
PostPosted: Sun Dec 01, 2013 8:15 pm
Thanks, I will remove the chain catcher and check parallelism again and see if that helps any. I will post back with my results.
PostPosted: Sun Dec 01, 2013 9:44 pm
For the moment it seems the chain catcher was the issue. I removed it, reinstalled the Derailleur with the original shimano bolt and checked paralleism again. Shifting seems much improved on my very short test ride.
Not only was shifting improved, but it allowed me to tighten the high limit a LOT more than I was able to before. Would that be a normal response to the reduced flex on the cage? Also, how does the chain catcher contribute to flex in the FD?
I am going to go out for a longer ride in an hour or so to see if the problem is resolved.
Thanks for the suggestions. I will let you know if that resolved the issues.
PostPosted: Sun Dec 01, 2013 10:07 pm
Online
Yup. As I said, some chain catchers have smaller bolts or cause flexibility by making the fixing bolt engage less threads.
My RCA
PostPosted: Mon Dec 02, 2013 1:23 am
Im using an exact setup you are. Stock bolt/mount plate, then no washers and the catcher in between.
Also using the stock support plate, have it parallel, and run QRings, no issues with shifting. Running 9070 Di2.
Interesting removing it solved the problem.
PostPosted: Mon Dec 02, 2013 1:28 am
I was not using the stock bolt. I was using the one from K-Edge. In fact, I am still not using the stock bolt, I am using a M5 bolt that I have from another build that is the same length as the Shimano bolt. My FD-6870 did not come with a bolt, so I am actually looking around trying to find a place to order a bolt/plate.
PostPosted: Mon Dec 02, 2013 2:41 am
FWIW...I'm using a K-Edge (new style) chain catcher on my 6870 also. Just a thought...maybe when removing the chain catcher, possibly set the inward 'pre-angle' more, before screwing in the support bolt. Thus providing more rigidity?
I did notice installing the chain catcher it comes with a short bolt and a long bolt. The long would have bottomed out on something inside the FD without fully tightening unit to the bracket. Had to use the short bolt.
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
PostPosted: Wed Dec 04, 2013 6:01 am
OK, I got the new shimano bolt and radius washer in today from the shop. I installed that. I have also reset parallel. Shifting is better, but after longer test rides it is still not where I think it should be.
I snapped a few pics as was hoping you guys could check to see if I have parallel set correctly.
PostPosted: Wed Dec 04, 2013 9:02 am
Online
Wow. Looks fine. I am now officially stumped. With the 9000 crank the shifting should be perfect. Sorry to repeat, but I assume you started with the FD angled in and then used the support bolt to get it parallel thus ensuring the support bolt was bearing the load. Other than getting it as low to the chain ring as possible, I'm out of ideas.
My RCA
PostPosted: Wed Dec 04, 2013 2:00 pm
I did start off a degree or 2 toe in and let the support bolt push it out a bit like it states in the dealer manual.
I am using a DA Cassette and Crank but 6800 chain. Would a 9000 chain have the potential to help?
I also checked the torque on all the chainrings and checked for play in the BB. Both good.
PostPosted: Wed Dec 04, 2013 2:33 pm
Online
Chain wouldnt make a difference.
My RCA
PostPosted: Wed Dec 04, 2013 2:57 pm
I am a little under 1.5mm now height-wise. I may try to lower it. Other than that, I guess I will just deal with it. I thought at first maybe I was just being picky (after just spending all that cash on Di2!), but I do have a frame of reference, as I rode a Madone that was newer than mine with 6870 this weekend. Front shifting was superb.
My symptoms now are just a tad different. It just seems that on occasion my chain will chatter/grind/etc for a brief moment before grabbing the chain ring and riding up on to the big ring.
PostPosted: Wed Dec 04, 2013 4:04 pm
Like I said, I run Qrings...if anything shouldn't shift worth crap, it would be those...but it is near flawless. The only issue with QRings is due to the lower teeth as they come around, shifting will delay, or "mis-catch" slightly, but the larger part comes around of course and it jumps right on. So it is a slight hesistation/catching issue very intermittent...but I've learned to shift at a specific point in the stroke, as you come around to the largest portion, ease off the pedal slight on the downstroke mid-way, and it catches almost perfect every time.
So basically I've learned to always have the largest/highest tooth coming around under the FD cage almost every time. Well, I try, not possible in every circumstance, but 80% of the time I do that.
Setup parallel, 9070 Di2. CN-9000 Chain, Sram OG-1090 Rear Cassette. Height is about 1mm above the very largest tooth at the biggest point of the QRing.
Keep working with it and tweaking it, you will get it eventually.
Last resort, might try different chainrings as a test...might be the issue. The way it is machined/ramping etc...could be causing the intermittent issues. I don't think there is such a thing as perfect every time shifting after 30yrs of riding. But I must say this new 9070 Di2 is about as close as it gets.
PostPosted: Thu Dec 05, 2013 4:35 pm
So, another couple of things.
1. I am running a 52/36 crank. The bike I test rode (where shifting was flawless) was 53/39. Does performance suffer that much on a compact, or in this case semi-compact, crank?
2. I was cleaning the bike up last night while I was making more adjustments and checking for other possible issues. I also had someone else ride it who immediately said something was off with the front shifting. When cleaning, I noticed a lot of metal shavings coming off the chain. I have never experienced this in 12+ years of cycling. The DA crank already looks to have some wear on the inside of the small and large chainrings. There are less than 200 miles on the crank/rings, which is where I suspect the shavings are coming from. Is this normal on a new crank?
PostPosted: Thu Dec 05, 2013 4:39 pm
Online
1. There is a slight difference in performance, but you are running shimano rings so its imperceptible. I am running praxis 52/36 on my 9070 system and the shifting is perfect. I can shift under full load without concern.
2. This is not normal.
My RCA
There are no new unread posts for this topic. Chorus 11-speed front der. shifting issue
Catagory6
Tue Oct 24, 2017 12:21 am
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Front shifting with close ratio cassette
vinuneuro
Fri Aug 25, 2017 2:57 am
2lo8 View the latest post
There are no new unread posts for this topic. Sram Etap shifting noise/problems shifting smoothness.
Allen254
Tue Jan 16, 2018 6:57 am
jlok View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
737
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
Users browsing this forum: HammerTime2, jimaizumi, MagicShite, springs, tibikeboy and 33 guests
