Look 695 c-stem replacement
boidos
by boidos
Hi all. I'm looking to run a regular ahead stem on my look 695..couple of quick questions.
Has anyone else done this successfully. The steerer tube has 2 flat sides but a regular stem seems to fit ok.. Did you need to put in an expanded plug, if not what did you use for a top cap,
thanks!
OrPe
by OrPe
it is doable without issues (i remember justin - look usa - answering this on RBR forums).
regarding the expander - i think it's not needed - but better contact look to validate.
ORen
Wcl4
by Wcl4
You can buy a tune gum gum compression plug and cut the rubber and grind the aluminum base a bit to make it fit the steer tube.
