Carbon Handlerbars for roadbike
Hi there
i was recently advised by a very knowledgeable source that if you are over 70kg in weight you should not use carbon bars as they will fail at somepoint?
Anyone know any different
I am 90kg in weight
I am 90kg in weight
- Juanmoretime
- Administrator
I think I would go with the manufacturers set weight limit. They would not recommend a weight that would be okay knowing that there is a possibility of failure. I weigh 72 kg and have been on the same 173 gram Zipp SL carbon bars for over 7 years.
RESIDENT GRUMPY OLD MAN.
thanks for the reply
the bars are Deda Superleggero but Deda do not provide any weight limits
thanks - and previously had you used carbon bars?
are you using the stem to?
Reason: deleted the quote. this is a reply. thanks.
I use the stem as well on one bike.
I am also using on other bikes ritchey carbon curve (on 2 bikes) and FSA compact carbon.
Reason: deleted the quoted quote as this is a reply. thanks
GregSherwin wrote:Hi there
That's ridiculous. 70kg is 11st. That's not very heavy by any standards (except perhaps for jockeys). Think about the average weight of the MAMIL who can afford to spend a couple hundred bucks on a handlebar. If 70kg was a sensible limit these things would be out there failing under normal use every day.
I'm on the heavy weight site +90kg and have been using two 180g bars. On my mtb bike I've got 83g bar. Never experienced a failure. But when something goes wrong don't quote me on this
I'd find a better knowledgeable source, yours sounds like a bit of a pillock.GregSherwin wrote:i was recently advised by a very knowledgeable source that if you are over 70kg in weight you should not use carbon bars as they will fail at somepoint?
At a given weight, carbon bars *should* be stronger and more durable.
And IIRC one manufacturer (Easton i think?) used to recommend changing their lightest aluminium MTB bars yearly, their (even lighter) carbon bar initially had no recommendation, then i think went to 3 years.
Only downside to carbon bars is that they are so exposed if you crash, and after a big slidy off, i'll usually replace the bars as a matter of course. And a €50 aluminium bar hurts the wallet a lot less than a €200 carbon one. (Plus the fact that you tend not to save huge amounts of weight, compared to dropping €150 on something else shiny!)
Disclaimer.- if you buy cheap nasty carbon bars, you're on your own.
Well, then he isn't very knowledgeable. Carbon has been used to handle tasks that involve weights far beyond human body weight. Just a matter of how you make it.
I am 90kg in weight
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
www.falcobike.com
carbon has some of the highest tensile strengths out there and can handle much more than just 70kg.
now, if you accidentally overtightened your stem and crushed your bars, or crashed in a manner as to whack your bars a good one.... well thats a different story....
The key here is "at some point". For a pro riding Paris-Roubaix a set of $300 carbon bars may well be one-use disposable. It essentially doesn't fatigue but doesn't take abuse well so make up your own mind. $/gram weight savings for carbon bars is unfavorable relative to many other options for weight savings, if you compare to the lightest Al bars.
Carbon bar weight saving over alloy may not be huge but the shaping can be more sophisticated and they feel warm to touch rather than cold. I like carbon bars.
Anecdotal evidence, but the only broken bars I've seen have been alloy.
Miller wrote:Carbon bar weight saving over alloy may not be huge but the shaping can be more sophisticated and they feel warm to touch rather than cold. I like carbon bars.
Once you forget about trying to make them light I agree you can do cool stuff with carbon.
That said, this was my GF's bars, removing her from the lead group on the final lap in her first-ever cross race in 2007:
A potential race podium is a major price to pay for a few grams.
That said, I think carbon bars have improved since then. Those old Eastons had a bad reputation.
- Similar Topics
- Replies
- Views
- Last post
- 4 Replies
- 1100 Views
Last post by kgt
Thu Aug 31, 2017 11:52 am
- 35 Replies
- 4142 Views
Last post by 3Pio
Fri Oct 27, 2017 9:48 pm
Is carbon lugged dead? Have modern monocoque frames usurped carbon lugged frames outside of just weight?
by tranzformer » Thu Jul 13, 2017 12:56 pm » in Road - 17 Replies
- 3297 Views
Last post by spartacus
Sat Jul 22, 2017 4:14 pm
- 5 Replies
- 641 Views
Last post by ms6073
Fri Sep 29, 2017 11:30 am
- 9 Replies
- 1022 Views
Last post by Butcher
Fri Nov 10, 2017 5:15 pm
