Campanolo 10sp Record bottom bracket question
dgasmd
by dgasmd
I've had this campy 10sp Record group on one of my bikes for about 5 years now. The bottom bracket feels like it is grinding big time when I turn the pedals. I have isolated it by a process of elimination to the bearings. Last night I took it all apart and the bearings feel like grinding sand. I degreased and cleaned the heck out of it and re-lubed heavily with white lighting grease. Same for the cups. I put it all back together and it feels smoother, but nowhere near as smooth as my SR 11sp bottom bracket bearings on my other bike.
I would like to replace the bearings on the 10sp with SR ceramic bearings. So, do I simply removed the cups from Record and replace them with SR cups? Do I replace the 10sp Record bearings with the SR bearings and seals? Is this a straight swap? Do they fit interchangeably? Is there anything i need to know or do other than a straight swap? I guess I will also need to get a bearing pulling tool as I don't have one. Any in particular recommended?
bikerjulio
by bikerjulio
Park make a good bearing puller, and driver as a kit for UT bearings.
Many experienced people will say that ceramic bearings here are a waste of time and money, and Campy steel bearings are excellent. But if you really want to swap, it is a straight swap for the bearings.
The only difference with the SR cups is that they eliminated the inner seal in order to slightly reduce seal drag. Depending on the frame these are going on, and the conditions you ride in, this could be a very bad idea.
The old cups will work fine, or you can replace - up to you.
Reason: deleted that quote as this is an reply.
There's sometimes a buggy.
One.
stella-azzurra
by stella-azzurra
Or you could just buy the ceramic bearings and replace them.
I would buy the bearings at VBX online or similar place for a fraction of the cost.
dgasmd
by dgasmd
So in other words, I can freely swap the UT Record cups and bearings for the SR UT Cult cups and bearings without any modifications. A straight swap! In the end, I may end up keeping the regular non-Cult bearings/cups as there is tons of salt and fine sand around here that gets into everything!
