It is currently Sun Jan 21, 2018 11:54 am
PostPosted: Fri Nov 22, 2013 3:14 am
Anyone know if they exist? Or if there are plans to make some? If not, what is the lightest available, even if it is not Ti?
Thanks!
PostPosted: Fri Nov 22, 2013 6:44 pm
I would say that the Red22 cassette is as light or lighter than anything you could make out of ti.
PostPosted: Fri Nov 22, 2013 8:53 pm
Several low-volume brands are on eBay. for example:
http://www.ebay.com/itm/RED2-TR-SUPER-L ... 5af5612a2a
You might do a search for your desired cog range, and include the word "titanium" in the search.
Hope that helps.
PostPosted: Fri Nov 22, 2013 10:14 pm
+1, and it will be far more durable. It's seriously light at 151g for an 11-25, and all cogs but the largest one are steel. Also, interestingly, the cog spacing for all 11sp cassettes (whether from SRAM, Shimano or Campagnolo) is more or less identical, so they are all interchangeable as long as you have a wheel with a compatible freehub. I'm actually thinking of running the Red 22 cassette with my Campagnolo setup when I next need to change my cassette.
<edit> Well, Ok, the Ti cassette linked above is even lighter, but it will wear out in no time.
<edit 2> Actually, the cassette above is alu with a Ti coating... Cheese might be better. Perhaps something reasonably hard, like a Gruyère or even a Parmesan.
PostPosted: Fri Nov 22, 2013 10:30 pm
I was a little miffed that the Red 22 cassette was so expensive but I went ahead and got one anyway. When I laid hands on it I must say, what a beautiful piece of engineering to be so light and yet made of steel, and all one piece except for the 11 cog. I think it's great now and when I wear it out one day it'll make a great paperweight!
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Fri Nov 22, 2013 11:43 pm
Not much of a paper weight though.
www.thecycleclinic.co.uk
PostPosted: Sat Nov 23, 2013 1:21 am
recon makes a full ti 11 speed cassette with aluminium spider. they are light and shift very nicely. they last fairly well too I've had one of the, on my road bike and put and this is just an estimate 4k miles on it before it was shifting poorly enough to replace it.
PostPosted: Sat Nov 23, 2013 7:34 am
Exactly what I needed to know. Thanks a lot! I'll probably go with the red 22 one.
:thumbup: :beerchug:
There are no new unread posts for this topic. Attachment(s) SRAM or Shimano 11 speed cassette
DeLuz
42
4185
Mon Jan 01, 2018 4:54 am
fh8425 View the latest post
There are no new unread posts for this topic. Cassette for 10 speed shimano
vejnemojnen
Sun Jan 14, 2018 10:22 am
vejnemojnen View the latest post
There are no new unread posts for this topic. Shimano vs. Sram cassette shift quality
vinuneuro
13
1292
Fri Aug 25, 2017 3:47 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Need a good value climbing cassette: 11-30, or 11-32 (SRAM/Shimano)
Shrike
38
4005
Fri Jun 23, 2017 5:15 am
basurper View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
Users browsing this forum: dim, Francois_Viviers, Google Adsense [Bot], themidge and 28 guests
